I am about to build this box in 2 hours with a friend, so any quick input would be nice, I did a lot of calculation, tried to keep port bends as low as possible, only 1 bend, port area I think is good, especially since im putting these 2 subs on 2.5x power daily, a kicker zx2500.1 for 2 Sundown SA-12's
Let me know if you would change anything quick, from what I can see its setup well, but when you been working on something for the last 6 hours you sometimes miss stuff
in torres calc it wasn't calculating the port area correctly, so I found the box internal volume after all displacements and then acted like the port was external to the box, winISD and torres gave me the same tuning when calculating it that way, I am going for 34hz with 3.22 cubes inside, I would have went bigger with the box but with the extra power I need a bit smaller airspace for sub control, I measured the Port Length right down the middle which is what your supposed to do I believe
Just let me know if I messed up on anything, even if you look at it quick, at least say yea or no or something, THANKS A BUNCH GUYS!!!
Edited by dereileak
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
I only have 1 but it is running almost identical tuning and size and port area as the box you designed and it sounds fantastic, I am sure you will be happy with yours set like you have. Not sure how they will handle that much power daily in that settup, but this guy burped 1 sa-12 with over 5k watts so I think you should be ok
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
Awesome :D Thanks for the input, I hope it sounds good too, I am excited, I have waited so long to finish my build
Pioneer 4300DVD
Break them in properly and you won't be disappointed at all, nobody believes all I have is 1 12 in my trunk, can't imagine what 2 with 2500 watts to them will do!
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
Wow man you got me so excited :D I haven't had nice subs for 8 months now, and they were in a horribly designed sealed box, so holy shit i"m happy, how would you break them in? keep the power lower for a bit?
Pioneer 4300DVD
Wait, you have all that fancy shit in your car and you're asking me for advice? I think you're messing with me, lol
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
Anyones help is appreciated, the box is all cut, im putting it together tomorrow, very excited :D doing something awesome with the baffle ;) some very neat lighting
Pioneer 4300DVD
Breaking in a sub takes roughly two weeks. Crank it up at times for two weeks and you'll be fine. They can take a 1500 or a 2500 with no problem.
1 pr Sundown Audio Sa Cs 6.5 component set
1 Sundown Audio sax 125.4
4 Sundown Audio sa8v2's
2 1500's strapped to 2ohms
1 Tenney 270 alt
the suspension on SA woofers aren't so special that they require special break in procedures. just slam full tilt out of the box. the less power you feed them, the longer it will take for the suspension to loosen.
awesome thanks, the box is almost done, just have to cut the woofer holes, it weighs 107 lbs, its freaking rediculous
Pioneer 4300DVD
  • Who's Online   0 Members, 0 Anonymous, 1162 Guests (See full list)
