Brights turn on when turning left?
pull the loc. try it agian. see if still does it. wouldnt be the first time Ive seen everything pulled out and returned back to stock and the issue is still there. Then you get the sheepish oh um i maybe it was doing that before. People are shady and will try to get over on anyone and anything
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Okay this might be a long shot but...
The red/white wire that you connected you remote line wire to is the 12v power feed for your stock cd player. To my knowledge, the remote wire for aftermarket amplifiers requires less than that, probably more around the 3-5v range I'm guessing. If your pushing more voltage to the amp, it could be making an excessive draw on the factory wiring, and in turn the amplifier might just be grounding it out.
Like I said a long shot, but hopefully this might help! I would disconnect the remote wire and see what happens. And I had an 02 Impala, electrical nightmare, goodluck!
Car: 2011 Ford Taurus SEL / Alt: DC Power 270XP (Will be here 7/17!!!)
Deck: Pioneer AVIC-Z140BH / Amps: (1) DC 5.0k, (1) RF T400-2
Speaks: RF T2652-S 6.5" and RF T1692 6x9"
Subs: (2) DC XLm2 15's / Batts: (2) XS XP3000's
Wiring: Kolossus Fleks Kable 1/0 (2 runs)
If you return everything to stock condition and everything is right and the problem still exists, then shoot the multi switch (by shoot I mean test) and see if that's the problem. Also if you don't know what the multi switch is, it's the turn signal/high beam assemble on the steering column. you can get a new one for usually around $50-80. Good luck.
This might not be applicable to your vehicle, but something similar happened on my Bronco.
I would hit the brakes or flip the turn signal switch to that side and all of my exterior lights (except for the headlights) would come on.
Turned out one of the bright filament legs somehow got bent and was touching one of the dim filament legs. The whole time I thought it was just my relay acting up.
2016 Ford Focus SE
No build log yet
DC Audio 1.2K
2x DC Audio Level 2 10"
  • Who's Online   0 Members, 0 Anonymous, 1430 Guests (See full list)
