Skrilla Posted January 13, 2013 Report Posted January 13, 2013 I recomend a isky triple 12 cam with a blackbear tune and a 3000 circle d stall That's a tiny cam, and is preferred for forced induction applications. I would go with a custom grind cam, if you plan on going that route. It's not very much more than an off-the-shelf cam. Also, don't get a mail-order tune. Do it right, and get a custom dyno tune. 2 HDC3 18's AQ2200D
OrionStang Posted January 13, 2013 Report Posted January 13, 2013 Dyno tune regardless what route you take. Mail order is hit or miss, as each motor and setup is different, even with all the same parts. SMD Super Seller My Feedback Thread
ToNasty Posted January 13, 2013 Report Posted January 13, 2013 Blackbear is a great tune. I'm very happy with it on my 4.8. . Made a huge differance ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Skrilla Posted January 13, 2013 Report Posted January 13, 2013 Blackbear is a great tune. I'm very happy with it on my 4.8. . Made a huge differance Now go get a real dyno tune, and you can tell us how much better it is than your current tune... lol 2 HDC3 18's AQ2200D
CleanSierra Posted January 13, 2013 Report Posted January 13, 2013 No ECU tune will be needed on a NON EFI motor, since there wont be an ECU, so throw Black Bear out. Engine is good for a solid 300 in my opinion. I'd get my power out of valve train if I were you, and breathing mods, air in, air out. Why go with a turbo 400?!?!? You're wasting all that torque in my opinion. A 4L60E has a MUCH lower first gear ratio, like 3.5:1. You'll holeshot like a motherfucker with a 700R4 or 4L60E. That's just my opinion. What rear end and gear ratio will you be running? Im not the one you want to try to troll. Just a fyi for you.
Skrilla Posted January 13, 2013 Report Posted January 13, 2013 4L60E's are junk compared to 400's. lol 2 HDC3 18's AQ2200D
CleanSierra Posted January 13, 2013 Report Posted January 13, 2013 ^^^haha, built well a TH400 can be nice, but it lacks low end grunt. A well built 4L60 or 4L80(or 85) can handle a shit ton of power. Plus you have Overdrive Im not the one you want to try to troll. Just a fyi for you.
ToNasty Posted January 13, 2013 Report Posted January 13, 2013 Blackbear is a great tune. I'm very happy with it on my 4.8. . Made a huge differance Now go get a real dyno tune, and you can tell us how much better it is than your current tune... lol If it was a track vehicle I would have but its a daily/work truck. No need for that. Which is why I went with the isky 12 can. Everything is mild ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
CleanSierra Posted January 13, 2013 Report Posted January 13, 2013 I'll happily take a 4L60/80 all day over a non OD outdated trans. You might as well suggest a Powerglide. High/low and done... Im not the one you want to try to troll. Just a fyi for you.
OrionStang Posted January 13, 2013 Report Posted January 13, 2013 No ECU tune will be needed on a NON EFI motor, since there wont be an ECU, so throw Black Bear out. Engine is good for a solid 300 in my opinion. I'd get my power out of valve train if I were you, and breathing mods, air in, air out. Why go with a turbo 400?!?!? You're wasting all that torque in my opinion. A 4L60E has a MUCH lower first gear ratio, like 3.5:1. You'll holeshot like a motherfucker with a 700R4 or 4L60E. That's just my opinion. What rear end and gear ratio will you be running? You liked your own post. SMD Super Seller My Feedback Thread
