Is a box tuned to 41 or 42 hz safe for daily driving?
Mobileaudio25
Listen to it set at 35 and see if you don't hear any nasty mechanical noise. Might be able to lower it closer to 30 idk its hard to say. I would really have to hear it in person.
Hows it sound down around 33ish with that enclosures 40's tuning? Kinda quiet and mostly moving air?
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
2 Sundown E12 Ported 4cubes 35hz
Rockford P400-4
2 Infinity reference 3way 6x9
2 Polk DB 5 1/4
2x layer dynamat all doors
It should be around the f3 of your enclosure but that is hard to know without the right tools
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
It depends on the woofer as well, some are built for lower tuned boxes, and some are built to work better tuned higher.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
If you had the new smd impedance detector, it can help find the f3 right?
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
Rockford P400-4
2 Polk DB 5 1/4
I run the dd3512's and slamminbeats said that he thinks 38 hz is the best tune for them. He said if tuned lower than 34 it's pointless because it doesn't play any lower.. He said they do well covering a lot of frequencies
find your f3 on the TL or do [tuning/2]/2="x" tuning-x=f3 point in theory i believe??
so 40 hz/2/2=10 40-10=30hz=subsonic set to here, again im not 100% sure and this is allllll theory
the lower you tune, the lower they will play, with DD's for some reason they just dont need to be tuned low to accomplish that, i was tuned at 36.5hz and played 20 hz full tilt safely...
edit: i guess my power was a little on the low side, still louder @ 20 than on my 9512s, these lil f*cker wont play 30 w/o freaking
that is a decent rule of thumb but nothing can substitute for an actual tool
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
i agree
  • Who's Online   0 Members, 0 Anonymous, 793 Guests (See full list)
