Pro Audio Subwoofers In A Car Audio Setup
I was thinking today about having Pro Audio subwoofers in a car. I mean their generally cheaper, and they are much more efficient. I once wanted to run an 18" Pro Audio sub in my car but the issue was it was an 8 Ohm woofer which was difficult. But If I had 4 woofers I could get an impedance of 1 Ohm which is perfect for most amps.
These for example:
http://www.ebay.com....#ht_4183wt_1398
The description seems to be missing but the title says '1000w', so we could presume 500w RMS, so with 4 18" woofers I would only need a 2000w RMS amp (I'd go a bit over but just as an example).
Are there any member rides on here using Pro Audio subwoofers?
How would 4 of these compare to my single Fi SP4? I would assume Pro Audio subs wouldn't be able to play the lows as well but tuning could help?
Specifications from Eminence:
Resonant Frequency (fs) 28Hz
DC Resistance (Re) 5.3
Coil Inductance (Le) 3.43mH
Mechanical Q (Qms) 10.38
Electromagnetic Q (Qes) .33
Total Q (Qts) .32
Compliance Equivalent Volume (Vas) 493.19 ltr/17.41 cu. ft.
Peak Diaphragm Displacement Volume (Vd) 796.00cc
Mechanical Compliance of Suspension (Cms) .25mm/N
BL Product (BL) 18.9 T-M
Diaphragm Mass inc. Airload (Mms) 128.1 grams
Efficiency Bandwidth Product (EBP) 84
Maximum Linear Excursion (Xmax) 6.7mm
Surface Area of Cone (Sd) 1188.0cm2
Maximum Mechanical Limit (Xlim) 15.0mm
(Old Car) 1995 Volkswagon Golf MK3 2.0L:
Fi SP4 18 On A DC Audio 3.5K In A PWK Box
Hertz DSK 6" Speakers, Clarion HU
3x Fullriver 120aH AGM's, 225A Alt
2012 Subaru BRZ:
Audison Prima APK 163
Bit One, Rockford Amps, Audison Sub
I can help much buy here's my friends set up in his car. All Menace audio. IB set up. The set up is very simple and sounds pretty damn good. Im sure your not gonna get the flex or excursion to get much out of them. but if you got the time and the little extra money to have fun to do a different set up i say go for it.
If it's worth building, it's worth over building.
Thats really cool! So do you think even if I had 4 of these Eminence woofers they would not be as powerful as my single Fi SP4 3000w RMS sub I have now?
I'm wanting to get louder and I'm only taking this option because it would be cheaper than buying another Fi SP4 because then I will need 6000w RMS of power at least.
2012 Subaru BRZ:
woa those are some loud ass mids in the vid, and aren't pro audio subs really just midbasses lol
"Damned if i do, damned if i don't..."Sold to: RodeoSport, deeppinkdiver, kevosinn, CortezDTV
Bought from: SlamminBeats, Carboardcat15
jose @ beyma uses the beyma pro audio subs in his explorer. his setup is LOUD and comparable to some of these groundpounders with massive setups. he also has 8 18s though....lol
Why not try obsidian audio 18's? They're 600 rms and like $199
I am thinking the same...Obsidian 18s would be great for your plans, and 3k on 4 of them should get nasty...
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
4 of them would easily beat a single sp4. due to cone area and sensitivity.
It isnt about cone area, it is about displacement. The sp4 has what, 30mm one way? So 60mm p2p. So ~432 cubic inches of air displacement, not to mention motor force over the pa subs. 4 18 pa's have 6.7mm or 13.4mm peak to peak each. They have about 360 cubic inches of displacement. Soooooo, the sp4 can displace more air, handle more power than all 4 pa's, and has wayyyy more motor force.
