What are you running on stock alternator?
Im running a stock 120 amp alt
stock batt up front
1 lanzar opti 2000d at .5
1 dual 800x4 at 2 ( i know it dosent do rated but it works.)
2 re audio sxx 15
4 pyle 6.5
2 lanzar opti super tweets
Max drop at idle 11.9
Max drop at 1800 rpm 12.4
Im gunna add a marine batt with 160 ah this afternoon. Ill post back up probably tomorrow.
I just wish i had a funny sig.
stock 110 alt
kinetik 1400 up front, 800 trunk
Alpine mrp-m1000, Kicker zr1000 on mids ands highs (underatedasfuck)
Big 3 1/0 Tsunami OFC
Full tilt while driving 13.8-13.6
Full tilt idle 12.8
Current Setup: , 2 Fi sp4 18s in a big ass flat wall tuned to 23hz, Pioneer 80prs, 2 Digital Designs m3bs strapped @ 2 ohms, Banda ICE2000, Crescendo 800.4, 4 PRV 10MR1000s,4 Mclaren MLT300 Super Tweeters Kinetik 2000 XS Power 2700 & XS Power 3100s.
92 jeep cherokee 90 amp alt
2 apsms 1500 strapped at 1.8
1 polk audio 660
starter batteries- redtop, kentic hc800
rear batteries- 2 60 ah agm batteries, 1 stinger 2150
drop to 11.5 if batteries arent charged, 12.5 if they are fully charged
What wiring do you have?
A neg run from the alt case to rear batteries helped my friend ALOT
I'd put the 2150 up front and the 2x 60Ah AGM's in the back near the amps. By ditching the 2 you have up front, the more efficient your charging system will be.
Not to mention less weight = more gas miles
Let us know if you do :)
Alt: 78 amps
Sundown 3500W amp and some 600w amp for mids/ highs
2 optima blue tops and 1 xs d3100 all under the hood:)
2/0 welding cable throughout
Big 3
Voltage drops to around 10.8-11v
that voltage drop scares me
some amps can go all the way down to 8v before protecting lol not saying its good to run that low but yea that is scary
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
Everything copper 0 guage
2 runs of 0 guage pos to rear
0 guage grounds all over my damn car 14+ wires
2 Everstart marine maxx 124ah for a total of 228ah
Stock 115? Amp acura tl alternator. Voltage drop 14.2 to 13.4-2 for about 1-2 mins then 11.9-8. Really bad. Its basically the same as playing your sounds with the car not running and having the alternator "charge" the quicky drained batteries. After I have switched to Powermax usa 220amp alt,I never drop below 13.4 full tilt. That's with a saz 2500@1 ohm,and 2 four channels runnign in active with 160amp fuse
stock batt up front
2 re audio sxx 15
4 pyle 6.5
I just got everything hooked up and went and pounded on it for about 20 minutes checked voltage at amp, it was charging at 14.4 at idle worst drop i could get was 12.9 durring hard long hits, immediatly back to 14.4 after end of note. digging it!!
stock 90-110 alt
1 xs 51r up front
big 3 in knu 0 gage
t1000
in the process of adding a t400-2
votage drop into the 11s.....too scared to go more
Car: 2000 Honda CRV
Battery: XS Power D5100R
Alternator: Stock 90A
Head Unit: Pioneer DEH-X9500BHS
Front Speakers: Alpine Type S
Rear Speakers: JBL GTO 628's
Wires: All Knu 4g. Soon to be 0g. Big 3 in 0g
Volt Meter: SMD VM-1
Amps: Rockford Fosgate T400-2, T1000-1bdCP
Subs: 2 SSA XCON 15's Sealed
Tint: Privacy glass + 5% in the back and 25% in fronts
2011 outlander
Stock 120 amp alt (smart charge system)
2-AQ 2200 strapped for burps, drop to 11.9
1-AQ2200 for daily
Big 3 of course
1/0 pos & neg front to back
2 kinetik 1800's plus stock
While driving 12.6 (even with stereo off)
Stock idle when started 14.1 (smart charge) when playing system full tilt, 13.3-13.7.
2011 Mitsubishi Outlander
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Transmission line enclosure
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
P71,
Stock Alt. : 200 amp ... (can u believe that !!!)
I have a mechman alt., 250 amp, that was never installed. . .
Big 3, all Stinger 0 gauge, a single XS Power D3100 battery under the hood.
A single Sundown saz 3500d powering TWO FI SP4's 15'' @ 1 OHM. . . ( B2 Audio M1s MKII on the way)
600W RF powering 4 Jbl speakers for mids and highs
14.4V - 13.9V on highway, and i saw it drop down to 12.8 volts couple of times on idle.
What you think :shrug:
2006 P71
270A Mechman alt.
2 XS power D3100's, 1 under the hood, one in the trunk. More to come.
2 Stinger 0 gauge, 4 gauge runs front to back
Sony DSX-S300BTX AM/FM Digital Media Car Stereo with Bluetooth
Pair of Fi SP4 15''s
B2 Audio M1s MKII amp @ 1 Ohm
Front doors JBL P660C 6.5'' 2-way component system.
Rear doors JBL GT0938 6x9'' 3-way
Rockford Fosgate t600 @ 2 Ohm
Ram Designs box with 5'' port, ~ 3.6 cubic inches each facing back.
5704P Python 2-Way Responder Remote Start / Security Alarm. :shrug:
  • Who's Online   1 Member, 0 Anonymous, 1411 Guests (See full list)
