DubNDodge Posted January 22, 2013 Report Posted January 22, 2013 I am curious to what the most draw on the stock alternator that there has been. Trying to decide if I can get away with just upgrading batteries for now, and get a H/O alternator down the road. Plus I think it would be cool to see what the biggest system on stock alternator has been. Try to include: Amps put out by the stock alternator The batteries used What amplifiers Voltage drop while going full tilt If the big 3 (4,5 etc) has been done If there has been multiple runs of 1/0 Any other information that would that would be beneficial to know would be great. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
purplesyrup Posted January 22, 2013 Report Posted January 22, 2013 Im going to contribute, but do not have all of the data your asking for. Stock alternator : 150 amps Battery: Die Hard stock size for car Amp: Crescendo BC3500d Big 3: NO Wiring: 300amp fuse- 1 run of 1/0 and one run of 4 ga. (when I was running the 1/0, I said well hell, might as well leave the 4ga there and use it. more copper=better The highest clamp I have done was 2100w which im sure is all my electrical system can support. Now at the same time, I did not clamp it at any frequency below 40hz, so it could likely be higher on a 35 hz tone around the tuning of the barrel. Note: When I first got the amp, I had only the 4 ga for 2 days, and was waiting on my 1/0 to show up in the mail, I also only had a 125 amp fuse on the amp, I could not pop the fuse, the wire would not let enough current go through to allow the amp to blow it. So technically the amp could have only produce approx. around 1,500w tops off that wire and 125 amp fuse. So, so far, off of my stock electrical, leaving voltage drop out, if i go based off of 12.5v, I've carried approx 168 amps to the amp. then if I went based off of an idle at 13.8, thats approx 152 amps. (again leaving out voltage drop) So in my theory, and very little recorded data, I can tell pretty accurately that I only get about as many amps as my alternator can produce back to the amp. Edit: Also, I am in the process of picking out battery power and a 300amp alternator for this season,
momofx76 Posted January 22, 2013 Report Posted January 22, 2013 LOL I was reading your post and then I was like "wtf - what barrel???" but then I realised it was YOU lol. haha.
OG BudBone Posted January 22, 2013 Report Posted January 22, 2013 Alt: 140 amp Batts: Xs 3000xp and 5100 Amps: Dc 3.5k and stock Mids highs amp(300 watts iirc) Big 3 done 1 pos and 1 neg run to back batt Max voltage drop is a little under 13v surprisingly 1997 Trans Am WS6 Pioneer DEH-P5200HD 2 DC Level 4 M2 12s 4 cubes tuned to about 34hz DC 3.5k 1/0 Welding Supply Ultra Flex Stock 140A alt Stinger Fuses & Fuse Holders XS Power D5100 XS Power XP3000
DubNDodge Posted January 22, 2013 Author Report Posted January 22, 2013 Im going to contribute, but do not have all of the data your asking for. Stock alternator : 150 amps Battery: Die Hard stock size for car Amp: Crescendo BC3500d Big 3: NO Wiring: 300amp fuse- 1 run of 1/0 and one run of 4 ga. (when I was running the 1/0, I said well hell, might as well leave the 4ga there and use it. more copper=better The highest clamp I have done was 2100w which im sure is all my electrical system can support. Now at the same time, I did not clamp it at any frequency below 40hz, so it could likely be higher on a 35 hz tone around the tuning of the barrel. Note: When I first got the amp, I had only the 4 ga for 2 days, and was waiting on my 1/0 to show up in the mail, I also only had a 125 amp fuse on the amp, I could not pop the fuse, the wire would not let enough current go through to allow the amp to blow it. So technically the amp could have only produce approx. around 1,500w tops off that wire and 125 amp fuse. So, so far, off of my stock electrical, leaving voltage drop out, if i go based off of 12.5v, I've carried approx 168 amps to the amp. then if I went based off of an idle at 13.8, thats approx 152 amps. (again leaving out voltage drop) So in my theory, and very little recorded data, I can tell pretty accurately that I only get about as many amps as my alternator can produce back to the amp. Edit: Also, I am in the process of picking out battery power and a 300amp alternator for this season, That's a nice stock alt. Mine is only a 90A. But still, running 3500w off stock electrical is pretty awesome, even if your not getting full power out of it. iirc I saw someone on here that was running around 5k, but had like 2 or 3 xs batteries. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
[email protected] Posted January 22, 2013 Report Posted January 22, 2013 Alt: 78 amps Sundown 3500W amp and some 600w amp for mids/ highs 2 optima blue tops and 1 xs d3100 all under the hood:) 2/0 welding cable throughout Big 3 Voltage drops to around 10.8-11v
bigmescan Posted January 22, 2013 Report Posted January 22, 2013 110alt 1000.bd RF power 400.4 RF power stock batt up front xs power 1200 in back 0g front to back 4g to amps full tilt drops to 12.8 and no big3 yet running 2sa8v.2 SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
ccmotox99 Posted January 22, 2013 Report Posted January 22, 2013 stock 130 amp alt. 1 stinger battery. 1 Audioque 2200d. 2 10" DD 3500s. A little headlight dim, voltage rests at 14.2, drops to about 13.4ish -playing with different setups
purplesyrup Posted January 22, 2013 Report Posted January 22, 2013 LOL I was reading your post and then I was like "wtf - what barrel???" but then I realised it was YOU lol. haha. LOL, yea, i gotta quit calling it a box, cause a box it is not.. LOL Im going to contribute, but do not have all of the data your asking for. Stock alternator : 150 amps Battery: Die Hard stock size for car Amp: Crescendo BC3500d Big 3: NO Wiring: 300amp fuse- 1 run of 1/0 and one run of 4 ga. (when I was running the 1/0, I said well hell, might as well leave the 4ga there and use it. more copper=better The highest clamp I have done was 2100w which im sure is all my electrical system can support. Now at the same time, I did not clamp it at any frequency below 40hz, so it could likely be higher on a 35 hz tone around the tuning of the barrel. Note: When I first got the amp, I had only the 4 ga for 2 days, and was waiting on my 1/0 to show up in the mail, I also only had a 125 amp fuse on the amp, I could not pop the fuse, the wire would not let enough current go through to allow the amp to blow it. So technically the amp could have only produce approx. around 1,500w tops off that wire and 125 amp fuse. So, so far, off of my stock electrical, leaving voltage drop out, if i go based off of 12.5v, I've carried approx 168 amps to the amp. then if I went based off of an idle at 13.8, thats approx 152 amps. (again leaving out voltage drop) So in my theory, and very little recorded data, I can tell pretty accurately that I only get about as many amps as my alternator can produce back to the amp. Edit: Also, I am in the process of picking out battery power and a 300amp alternator for this season, That's a nice stock alt. Mine is only a 90A. But still, running 3500w off stock electrical is pretty awesome, even if your not getting full power out of it. iirc I saw someone on here that was running around 5k, but had like 2 or 3 xs batteries. Yea man, my first step is getting a 120lb northstar battery, Im working on that now, I will see what that bastard puts out then, the battery is 7000-8000 cranking amps. I ran one back in the day. We will see hwo much better that is, then go for the alt. Im kinda doing this one step at a time to have the enjoyment of watching the increases, and testing, I like to piddle around.
Pioneerchuck Posted January 22, 2013 Report Posted January 22, 2013 Alt: 130A Oreilly Super Start Extreme AQ 2200 MB Quart ONX4.80 Voltage drop lowest Ive seen is 12.49V NO big 3, NO 0ga. Running Knu 4ga from battery to 2200 and from battery to MB Quart 300A fuse for 2200 100A fuse for MB Quart Also have LED lighting for underbody, wheel wells, under the hood, bed, 2 15" monitors, and HID headlights.
