Trunk/hatch Corner Box: 1/2 Fiber Glass/mdf.
Making the "flares" on the trim rings.
Yes its just solid filler applied at an angle and sanded smooth...no pressure on it since it's 100% exterior and will be carpet covered.
Posted Image
Lookin gross...gotta get worse b4 it can get better.
Posted Image
Posted Image
Few angles to deal with/smotth out.
Posted Image
These are pretty awsome thus far...just need em in LOWER GRIT than the 120/180 I have.
BTW-GREEN STAGE SANDING FTW! SERIOUSLY.
Posted Image
SHAMELESS....
Posted Image
Back up on the bench
Posted Image
On this lil diamond shape....I painters taped the top edge of the diamond and taped it in place...then applied filler along the taped edge to give me this lil raised "lip" around the outside/top edge of the "point"....then shaped it better with the 1/4 sheet power sander...and then some hand sanding.
Posted Image
It chipped a lil bit but it will not be noticeable when the carpet is on so F-it.
Posted Image
Posted Image
:blink:
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
So apparently.....that lil "flex LED" strip....is not that flexible under 50 degrees F.... :angry:
Posted Image
Posted Image
primer
Posted Image
bracing/support
Posted Image
Posted Image
Posted Image
predrilled...
Posted Image
Posted Image
Posted Image
glue.........
Posted Image
Fiberglassed heavily from the inside.....then a skin coat of pepto.....
Posted Image
Sanding down the pepto pink.
Posted Image
I had to trim down the backside curve of the top corner....and angle-grind a new contour to the "point"/peak of the diamond shaped part.
Posted Image
Smoothed over the "unseen" back side
Posted Image
Posted Image
Curves and angles
Posted Image
Posted Image
Primered
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
More as they upload...I got a BOOOONCH more B)
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
The inside showing how I glassed it up thoroughly.
Posted Image
All the seams...
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Got logos?
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
  • Who's Online   2 Members, 0 Anonymous, 1811 Guests (See full list)
