Longbed = shortbed??
Herro, I was looking at some trucks on CL,and i really want a C10 shortwide. Buuuuuuuuuut all the ones i find are long bed (trucks in general that i like.) I just watching this
and it seems like turning a longbed into short isn't all that hard. Anyone have experience with this? cause there is some cheap ass trucks that if they were short box, i would buy it tonight
It is called "bobbing" the bed. You cut out a desired section of bed, generally behind the rear wheel well, and put the two sides back together. Most people that I see do it are doing it to decrease their departure angle of their truck (the rear overhang). You would probably be better off with buying a shortbed bed and putting it on a longbed chassis.
poopy :|
Since you would even suggest converting a long bed to a short bed I would assume you have some mechanical savvy. Why not get one with a long bed and search junk yards for the same model and color with a short bed and take it? Granted I would make sure one is available to do so before buying the truck
formerly known as Jaylor Swift
IMO like mentioned get a long bed truck and swap it out for a short bed, if its something thats not available be ready to fork over $$$ or do the good amount of work like in the video
theres a company out there that sells a kit to do this. im sure its not cheap but they do it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
In most cases, you can't just simply put a short bed on a long bed frame. The frame is longer. Same with bobbing the bed. The ends of the frame rails will stick out. However, you could section the frame to bring it in as well. It is pretty difficult mainly because your cuts have to be dead accurate and it's a lot of cutting.
but thats what you're gonna help me with! :D
I remember seeing a episode on "Trucks" where they did the long bed to shot conversion. I dont remember on what truck they did it on though.
If it's worth building, it's worth over building.
street trucks mag october 2012 volume 14 no 10. page 30. they do just this. no limit engineering sells the stuff to do it
nolimit.net
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
