bassaddiction Posted January 24, 2013 Report Posted January 24, 2013 i want to make a box for a ford explorer 4 15s facing up, port back. max 41 wide 38 deep 26 high. im going for spl on music, i listen to a lot of rap music can some help me design a box bc mdf isnt cheap. i dont know alot about port area or what hz to tune to. i think the box has to be 14 cubic ft after displacement. thats all i know lol so if someones board and want to help out, that would be cool thanks guys Outer Diameter 15.125" Mounting Depth 6.25" Subwoofer Cut Out Diameter 13.875" Subwoofer Displacement 0.15 ft^3 Sealed 2.5 ft^3 Ported @ 35Hz 3.5 ft^3
Joe X Posted January 24, 2013 Report Posted January 24, 2013 So here is a suggestion, real tight: Enclosure Specifications: Fb = 35 Hz Vb = 13.63 ft^3 External Height = 24 in External Width = 41 in External Depth = 33.75 in Port Width = 36 in Port Height = 4 3/8 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 41 x 33 3/4 Left & Right Sides = 32 1/4 x 21 3/4 Front & Back = 41 x 21 3/4 L Port Internal Assembly Parts: Front to Back = 12 x 37 1/2 Port Left Side Assembly: 12 x 4 3/8 Port Right Side Assembly: 12 x 4 3/8 Place a top to bottom crossbrace right at the center of the baffle and do the shown brace inside the port.
bassaddiction Posted January 25, 2013 Author Report Posted January 25, 2013 thanks alot man, thats just what i wanted. send me your number, if this comes out good, ill pay u for a couple more box designs i want to do 2 10 inch hdc3 in my 2 door truck and some other things.
bassaddiction Posted January 25, 2013 Author Report Posted January 25, 2013 also how big should the brace in the port be 8 by 4 3/8 is that good thanks again
Joe X Posted January 26, 2013 Report Posted January 26, 2013 also how big should the brace in the port be 8 by 4 3/8 is that good thanks again Make sure it starts at the inner end of the port, it is not made to the full length of the port for aesthetic reasons so between 8-10 whatever you consider looks best. Don't forget the top to bottom crossbrace to the center of the baffle. And if you want any other boxes drawn at some point just post up.
Ballen194 Posted January 26, 2013 Report Posted January 26, 2013 13.63 is a little big for them subs isn't it? And for spl purposes? 98 Isuzu Rodeo Pioneer Deh-6300ub SUBS*Upcoming* SSA Xcon 18 4th order AMP Banda 3500 Mids/Highs Pioneer EQ Clarion EQS746 ETC. Two 1/0 run's KnuKoncepts 1/0 big 3 Shuriken BT-100 under the hood Shuriken BT-120 in the back
Joe X Posted January 26, 2013 Report Posted January 26, 2013 13.63 is a little big for them subs isn't it? And for spl purposes? If you mean that the subs are going to bottom out, that's not happening even at 550W per sub. However, and I didn't mention this, subsonic filter should be engaged in most ported boxes half an octave below tuning frequency.
Hotdog Posted January 26, 2013 Report Posted January 26, 2013 What year explorer? How many watts? SPL purpose tune to 38hz for an Explorer. Will sound good and get loud box design looks good just tune it to 38hz do a 3/4 round over around the top of the box and around the port and sand it smooth. Better air flow will get you extra tenths on the meter. (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
bassaddiction Posted January 26, 2013 Author Report Posted January 26, 2013 99 explorer and 1000 rms for now, then 2000 later
Joe X Posted January 26, 2013 Report Posted January 26, 2013 99 explorer and 1000 rms for now, then 2000 later If listening mainly to rap and such I wouldn't tune to 38Hz, as is right now the box will perform well to 2.2K or 550W per sub. Also your subs should be dual 2 ohm to be wired at 1 ohm final load.
