AMP diagnostics help!
Agreene
So i recently re did my car ( adding 100 square feet of sound dampening ,4 channel amp and all new speakers and just a different layout)
general setup is:
hinfonics 1500x1ohm mono amp
hifonics 80x4
2 cadence s2w12's
2 sets of alpine type R components
MY ISSUE
recently i was driving home listening to my music ( not even loud) and all of a sudden my subs went off no blowing or popping sound so i figured one of my speaker wire came. well when i got home they werent out. I THEN noticed a strong smell ( i think coming from my monoblock the hifonics 1500) the mono block turns on with a green light. i replaced both fuses on the amp and still nothing, the subs are fine tested them inside with home amp. any suggestions i think i got a dead amp.. :{
If you smelt it it's probably roasted. If it is still under warranty send it in, if not, pop the back cover off and inspect the carnage. I would unhook that if you haven't already blown amps can be a major fire hazard if left connected.
I'm gonna hate
check the output of the amp with a DMM and see if you're getting a signal (most likely not if subs aren't working) and try another set of RCA's. could be the outputs went out and need repairing
I agree if u smelt it its probably toast all u can do now is get it checked out see if it can be repaired
  • Who's Online   1 Member, 0 Anonymous, 1074 Guests (See full list)
