CleanSierra Posted January 28, 2013 Report Posted January 28, 2013 You might here some mechanical noise you wouldn't have heard before. I agree, watch out for rubbing the surround on the lip of the mounting hole. Tuning does play a factor too, since it changes whether or not inverting. The only time you'd need to invert wiring, is if you're running one sub IN the box and one sub inverted. I run an isobaric push/pull and I have to run the inverted sub in reverse polarity Im not the one you want to try to troll. Just a fyi for you.
P4killer_ Posted January 28, 2013 Report Posted January 28, 2013 I always thought about the motor assembly blocking the wave off.of the back of the cone..aka lower SPL scores.. But you could always build the box with inverted mounting in mind. To save some space at least box wise if you needed an inch or two in one of the dimensions. Unless you're running big mofo motors, the space saved on a couple kicker comps won't change much though. It looks cool,but you gotta keep the speaker wire clean yo Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
BassMunky Posted February 1, 2013 Author Report Posted February 1, 2013 if it inverted the spl louder hmm.... sooo if i invert it it wouldnt matter how close the sub magnet close to the ceiling without touching it right? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted March 18, 2013 Author Report Posted March 18, 2013 bump Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
bassfreake Posted March 18, 2013 Report Posted March 18, 2013 If its a ported box wouldn't inverting the sub raise the tuning? Because it would be like making a bigger box with the same port size. Or am I wrong?bigger box means lower tuning Thanks I was pretty excited about the alt myself. kind of like a school girl, in a dress, on a swing. lol It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out. My Build Log
BassMunky Posted March 18, 2013 Author Report Posted March 18, 2013 less power? ^ Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
