Reno926 Posted January 27, 2013 Author Report Posted January 27, 2013 should i ground the rcas at the head unit or the amp... or should i get a new head unit
SnowDrifter Posted January 27, 2013 Report Posted January 27, 2013 Ground them at the head unit. Also double check all your connections and make sure the RCAs aren't next to the power wire ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
85buickrivi Posted January 27, 2013 Report Posted January 27, 2013 i had the same prob i did this works perfect
Raptorman Posted January 27, 2013 Report Posted January 27, 2013 That's genius. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Mojo Man Miller Posted January 27, 2013 Report Posted January 27, 2013 do you have an amp on your mids and highs? http://www.memphiscaraudio.com/My car: http://www.stevemeadedesigns.com/board/topic/160564-2000-camaro-2-mojo-12s-videos-up/#entry2314594
ThreehundredC Posted January 27, 2013 Report Posted January 27, 2013 I am in this same problem got new ground wirefor the amp got new ground wire location to the radio ..still noise when the car is on or reving
Carbon Posted January 27, 2013 Report Posted January 27, 2013 Probably your HU. I rattled the brains out of my little pioneer.
ThreehundredC Posted January 27, 2013 Report Posted January 27, 2013 so my RCAs are like the hanging kind it has like heat shrink at the bottom where it meets the headunit but i can see the wires in there how do u rewire it
Tarball Posted January 28, 2013 Report Posted January 28, 2013 so my RCAs are like the hanging kind it has like heat shrink at the bottom where it meets the headunit but i can see the wires in there how do u rewire it I took a length of wire and stripped the insulation off of it and did the same grounding method pictured earlier in this thread but at the end of the RCA "dangle". I used zip ties to hold the stripped wire to the RCA grounds then grounded the end to the HU chassis. This worked for a short time and now the whine is back slightly, gotta get in there is do something better to secure the ground to the RCAs. Maybe a spot of solder on each one with work better. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
