Kevin Geissler Posted January 28, 2013 Author Report Share Posted January 28, 2013 I gotta get on my computer after work. Idk if you can do it from mobile. As of now i have moved up to a Skar 1500.1 and i put my Kicker cvr 15 to replace the missing E15 so i can still have music. Quote Pioneer DEH-9400 Kicker door Speakers Rockford R400.4 Skar 1500.1 2 DC lvl 2 15s Link to comment Share on other sites More sharing options...
Banshee421 Posted February 3, 2013 Report Share Posted February 3, 2013 So my sa 12s are tuned using a dd-1 I tought I was safe tuned to track 3 for sq. Quote Link to comment Share on other sites More sharing options...
Hi-Po 5.0 Posted February 9, 2013 Report Share Posted February 9, 2013 Just cause you used a dd-1 doesn't mean it's the end of clipping Using the -10db track increases the possibility of clipping cause all songs are at different volumes So if a dd-1 doesnt stop clipping and distortion why is it highly sold and used? Is it a "kinda of sorta of distortion dectector?" Smh Quote 93' Exploder Deck:Pioneer 6400-bt Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2 Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs) Wire: All Sky High Car Audio Cable! Alternator: Singer 250 amp Hairpin Batteries: XS Power D975 Team Audio Connections Link to comment Share on other sites More sharing options...
barney91 Posted February 9, 2013 Report Share Posted February 9, 2013 Just cause you used a dd-1 doesn't mean it's the end of clipping Using the -10db track increases the possibility of clipping cause all songs are at different volumes So if a dd-1 doesnt stop clipping and distortion why is it highly sold and used? Is it a "kinda of sorta of distortion dectector?" SmhI'm guessing you don't know how the dd1 works. It doesn't matter if you use the dd1, if you play the wrong type of music you can still be clipping Quote Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1 Link to comment Share on other sites More sharing options...
Noel989 Posted February 9, 2013 Report Share Posted February 9, 2013 Just cause you used a dd-1 doesn't mean it's the end of clipping Using the -10db track increases the possibility of clipping cause all songs are at different volumes So if a dd-1 doesnt stop clipping and distortion why is it highly sold and used? Is it a "kinda of sorta of distortion dectector?" SmhI'm guessing you don't know how the dd1 works. It doesn't matter if you use the dd1, if you play the wrong type of music you can still be clipping I have a dd-1 and use it and recommend it to my friends or anybody I can After your done setting your gains you still have to keep an eye on your system this is were the ear comes in if your within your setting and you can hear/see distortion/bottoming out back it off a lil bit Dd-1 and some common sense=FTW Quote Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
bdog Posted February 9, 2013 Report Share Posted February 9, 2013 there are a few things that screw with you after the tune from a dd-1 like moving anything up on the EQ after tuning or playing already clipped music or dropping voltage. sundown rates the E at 400 watts and they know it takes 700 clean to kill it so when they see a thermal failure they know its user error. Quote REP Link to comment Share on other sites More sharing options...
Banshee421 Posted February 9, 2013 Report Share Posted February 9, 2013 I know for a fact a e15 cant handle 700 watts smelled it with my own nose. 1 Quote Link to comment Share on other sites More sharing options...
Hi-Po 5.0 Posted February 18, 2013 Report Share Posted February 18, 2013 I know for a fact a e15 cant handle 700 watts smelled it with my own nose. +1 Quote 93' Exploder Deck:Pioneer 6400-bt Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2 Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs) Wire: All Sky High Car Audio Cable! Alternator: Singer 250 amp Hairpin Batteries: XS Power D975 Team Audio Connections Link to comment Share on other sites More sharing options...
81000D Posted February 19, 2013 Report Share Posted February 19, 2013 Im running a e-12 on a mtx 81000d at 2ohms for one year now set with a dd-1 and it sounds great never smelly. Quote Link to comment Share on other sites More sharing options...
Big-A Posted February 19, 2013 Report Share Posted February 19, 2013 I dont know why everyone has been bashing the DD1. If you watch the videos that Steve and Tony have made you will realize that its is essentially an O-Scope with a dummy light. It shows when you have a clipped or distorted signal when used properly, 99 percent of the dd1 problems are user error. Even if you used a 0db track and used an o-scope, depending on what track you are listening to and how you set up the headunit/eq will still be able to clip at certain frequencies and burn up your drivers. Quote 2004 Dodge Ram Head unit- Alpine iDA-x305s Sound processor- Clarion eqs746 Mids/Highs amp- Alpine MRV-F345 Sub Amp- Alpine MRD-M1005 Dash Speakers- (3) Dayton Audio rs75 Front Door- Skar SPX65c Rear fill- Skar SPX tweters and Dayton ND140 midbass Sub- Fi Audio SSD 15 high QTS SHCA power/ground cables and Stinger interconnect XS power D6500 under the hood and D680 in the amp rack Big 3+ with SHCA http://www.stevemeadedesigns.com/board/topic/161174-dodge-ram-quad-cab-fi-ssd15-skar-audio-alpine-shca/?p=2326251 Link to comment Share on other sites More sharing options...
