Subs humming with rcas unpugged?
Okay, so I just rehooked up my system. Two Aq 15s, on a Rockford fosgate t.1500, all stinger wiring (1/0) and a battery in the rear.
So my problem is that once I hooked everything up and turned my truck on I got a weird quiet humming noise, so I pulled out my rcas and checked the connections. I pulled them out and I got a ear full off bass, like a constant note. loud thou. I've swapped my rcas with 3 different brands none ran close to the power wire or anything. What should I do now>? swap the ground again?
2001 Nissan Frontier3/5 drop
''Gutted"
Underconstruction
If you don't let your unborn swim in her mouth someone else will.
Hmmm.... Is your ground clean? Does it do this with the car on/off/both?
Do you have alot of extra speaker wire running your subs?
They could be acting as an antenna if they are touching anything
The ground is clean,I've used it before with another big system, the only thing is maybe some sound damper is touching the ground in some way? And the only speaker wire is 2ft of stinger wire coming off some stainless steel bolts im using as terminals. I've used all this before but never had this problem. I just hooked the rcas from the amp to the radio and it played full tilt at the boxes tuning.
''Gutted"
Underconstruction
So you hooked rcas from radio to amp and it plays fine?
If you unhooked the rcas from the amp and you still get a tone. Obviously its getting interference from some where. If the speaker leads run straight to the box I doubt their pinched or something.. so if the speaker wire is ok.. then your left with the amp.. I've had an amp send a humming noise to the subs but it wasn't loud. Needless to say I sent it in for repair. It's a process of elimination.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
No, with all of it hooked up I can play music and get bass, but its like the subs are already playing before I turn up the volume. My radio is a pioneer deh-500 something. I'm at a lose honestly. thanks.
''Gutted"
Underconstruction
Thanks for help guys, but it ended up being the RCA output of the amp. I guess it might have gotten loose but I got a local dealer to fix it. Was only 30$.
''Gutted"
Underconstruction
I had this issue. I have a t400.4 and a t1000bd and I noticed subs where making a noise. So I unhooked RCA's then it stopped. After messing with RCA's on both amps the noise stopped. And every once in awhile I will get a ground noise from my componenets. I've looked at every connection. I've pulled the HU out to make sure nothing loose there. And the only thing I can think of is the bass knob. I've unhooked it as well and had no noise. Ever since I've hooked it backup I've heard no problems. And its been about a month
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
  • Who's Online   0 Members, 0 Anonymous, 2052 Guests (See full list)
