DylanBunch Posted January 30, 2013 Author Report Posted January 30, 2013 1 ohm lol I have a dual 1 though. I mean its not a big deal having dual 1 right now cause I have a rockford 1000bdcp but in the future when I get a more powerful amp I wanna go 1 ohm 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
cloud77 Posted January 30, 2013 Report Posted January 30, 2013 so what are you hooked up at now? .5? You want to recone it with dual 2 ohm coils to wire it to a 1 ohm nominal load. 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
CW06Silvy Posted January 30, 2013 Report Posted January 30, 2013 universal means that the motor will work if you change the impedance. for instance say your sub is a dual 1 now and you want to change it to a dual 2. You'd be able to do this with your new recone if the motor is universal. Universal option does not cost any money at checkout on Fi's site, so just hope that the original owner selected it. But try and contact him to make sure. You can purchase a basket from Fi as well with the recone. They use the same 12 spoke baskets on all their subs except the sp4 universal means that the motor will work if you change the impedance. for instance say your sub is a dual 1 now and you want to change it to a dual 2. You'd be able to do this with your new recone if the motor is universal. Universal option does not cost any money at checkout on Fi's site, so just hope that the original owner selected it. But try and contact him to make sure. You can purchase a basket from Fi as well with the recone. They use the same 12 spoke baskets on all their subs except the sp4 Not quite there.. I can put any kind of coil in a motor if I wanted to.. I could do a single 4 ohm, dual 2 ohm, or whatever as long as the coil is the same diameter and fits the coil gap in the woofer. What I think he was referring to his "universal" statement is that each sub motor has a bolt pattern that attaches the magnet to the basket. Thus you have to have a basket that fits your bolt pattern, or you have to have someone machine the bolt pattern into the basket so that it will fit. 2006 Silverado Ext. Cab 6-15" SSA ZCONS 4th Order Blow-Through Pioneer AVH-P4200dvd American Bass VFL 1100.1 12 volt 6 C&D Batteries 2-350A Singer Alternators and Stock Alt DC Power Triple Alt Kit MLA Module 3 Runs of 1/0 2 Sets of Boston Acoustics 6.5 Pro Components Boston Acoustics 2-channel Lots of Sound Deadener ....Build still in Progress...
DylanBunch Posted January 30, 2013 Author Report Posted January 30, 2013 Right now im down to 2 ohms in series. But didnt someone say universal means it can be dual 1 or 2. Im confused 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
DylanBunch Posted January 30, 2013 Author Report Posted January 30, 2013 Ohhhhhhhhhhhhh ok I understand now ok 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
CW06Silvy Posted January 30, 2013 Report Posted January 30, 2013 Right now im down to 2 ohms in series. But didnt someone say universal means it can be dual 1 or 2. Im confused Right now im down to 2 ohms in series. But didnt someone say universal means it can be dual 1 or 2. Im confused You can put whatever you want for coils in that woofer recone. Dual 2 ohm means 4 ohms (series) or 1 ohm (parallel) Dual 1 ohm means 2 ohms (Series) or 1 ohm (parallel) Check with them to make sure that if you order a basket that it will fit your motor's bolt pattern before you buy anything. 2006 Silverado Ext. Cab 6-15" SSA ZCONS 4th Order Blow-Through Pioneer AVH-P4200dvd American Bass VFL 1100.1 12 volt 6 C&D Batteries 2-350A Singer Alternators and Stock Alt DC Power Triple Alt Kit MLA Module 3 Runs of 1/0 2 Sets of Boston Acoustics 6.5 Pro Components Boston Acoustics 2-channel Lots of Sound Deadener ....Build still in Progress...
cloud77 Posted January 30, 2013 Report Posted January 30, 2013 The bolt patterns are only different on the UFOS I believe. Might as well order the basket from Fi with the recone. As far as woofer wiring ^ this is correct. 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
DylanBunch Posted January 30, 2013 Author Report Posted January 30, 2013 Right now im down to 2 ohms in series. But didnt someone say universal means it can be dual 1 or 2. Im confused Right now im down to 2 ohms in series. But didnt someone say universal means it can be dual 1 or 2. Im confused You can put whatever you want for coils in that woofer recone. Dual 2 ohm means 4 ohms (series) or 1 ohm (parallel) Dual 1 ohm means 2 ohms (Series) or 1 ohm (parallel) Check with them to make sure that if you order a basket that it will fit your motor's bolt pattern before you buy anything. Right now im down to 2 ohms in series. But didnt someone say universal means it can be dual 1 or 2. Im confused Right now im down to 2 ohms in series. But didnt someone say universal means it can be dual 1 or 2. Im confused You can put whatever you want for coils in that woofer recone. Dual 2 ohm means 4 ohms (series) or 1 ohm (parallel) Dual 1 ohm means 2 ohms (Series) or 1 ohm (parallel) Check with them to make sure that if you order a basket that it will fit your motor's bolt pattern before you buy anything. Right now im down to 2 ohms in series. But didnt someone say universal means it can be dual 1 or 2. Im confused Right now im down to 2 ohms in series. But didnt someone say universal means it can be dual 1 or 2. Im confused You can put whatever you want for coils in that woofer recone. Dual 2 ohm means 4 ohms (series) or 1 ohm (parallel) Dual 1 ohm means 2 ohms (Series) or 1 ohm (parallel) Check with them to make sure that if you order a basket that it will fit your motor's bolt pattern before you buy anything. isnt parallel on dual 1. 5 ohms? 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
cloud77 Posted January 30, 2013 Report Posted January 30, 2013 Yes it is. Just a mistype I believe. =] 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
kandiman71874 Posted January 30, 2013 Report Posted January 30, 2013 Guys, the universal option with Fi means that the gap is large enough for a dual 1 or dual 2 coil. it has nothing to do with the bolt pattern on the motor for the basket. Each motor is machined per order and if the sub was ordered as a dual 1 and the universal option was not chosen, then a dual 2 coil will not work because the gap is not big enough to work with the thicker dual 2 coil. Daily Driver 1999 Kia Sephia Kenwood DNX-893s Audison Bit One Processor 2 Dat 4.125's Sundown Audio SCV-6k Hertz hsk-165xl's Mids running active Focal V30 Series Tweeters running active Sundown Sa-8 v1's in the doors 2 Sundown Zv5 12's Lots of Hushmat Big 3+ and 3 + & 3- runs of Trystar 2/0 2 Dc Power Engineering 320 HP Alts 2017 Comp Vehicle 2006 Toyota 4 Runner Kenwood Excelon DNX-893s Audison Bit One HD DSP 4 Sundown Sa 6.5v2 Component Sets Focal Access 6.5 2 ways Sundown Audio Sax-50.4 Sundown Audio Sax-100.4 2 Dc Power 370xp Northstar agm27f Northstar agm65 2 Northstar asmagm 480's 2 Dual 1 Sundown Nightshade v3 12's 2 Sundown SCV-7500's All SMD Fuse Holders Shitload Of Sundown 1/0 120 sq ft Second Skin Damp Pro No, Its Not A Burp Truck!!!! 2016 Season 3rd place in Xtreme 1 At Finals 2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations) 2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL David said: audio is a lifestyle, not a hobby newls1 I cant read a tape to save my life... 1/2's are ok, but other marks confuse me kingsuv only men who cant read a tape, take it in the ass kingsuv you sir, get a pink hard hat on jobsites
