I have 2 sa 12s and am getting 2 more in my 2000 blazer.....dont wanna get a high end amp just yet but was wondering if i should run 2 amps or 1? right now i have a hifonics 1500 and it slams nut want something different. 2 amps or 1?? help please
if your subs are d4 and u buy d4 two amps can get you to 1ohm per amp or 1amp at .5 or 2ohm
REP
You can get an AQ2200, then if its not enough, grab another AQ2200 later down the road.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
they are d4s but when i get the other 2 i can get the d4s or d2s and they will trade my d4s for d2s. so what will be the best route to go? and what brand is the aq2200???
Aq 3500 for 4 SA 12's... With properly set gain.
Technically they only should get 2400 rms....... But that's what I'd pick. Remember you can always turn the gain lower :)
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
thanks. its a little more than i wanted to spend but from what i read seems like it will do the job. i was leaning toward 2 soundstream 2500 rubicons but now i might get one of those instead
1 amp might be easier... No gain matching or strapping hassles.....
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
You tell us.... I just said I'd go with a 3500 rms amp and I'd go single amp for ease of set up
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
  • Who's Online   0 Members, 0 Anonymous, 1579 Guests (See full list)
