__d_a_v_i_d__ Posted February 7, 2013 Report Posted February 7, 2013 Foam. Expanded foam . Silicon . Gorilla tape . Then beaut panels Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
Kyblack76 Posted February 7, 2013 Report Posted February 7, 2013 I was rear fire. Swapped it, to fire in the cab. Only half assed sealed off. I played half a tone, and half of a song. And swapped it back. Was not even cool. Way quieter.... WAY.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
__d_a_v_i_d__ Posted February 7, 2013 Report Posted February 7, 2013 ^^ to add to this, I first had subs n port facing my side trunk than face it forward . Without sealing off, it was also way quieter! Butt still sealed it off world of a difference !! Every note was louder n it even able to hair trick now . Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
soundstream15 Posted February 7, 2013 Author Report Posted February 7, 2013 Very nice!! I didn't think you could seal it off firing into the trunk like that. Future ideas
Kyblack76 Posted February 7, 2013 Report Posted February 7, 2013 ^^ to add to this, I first had subs n port facing my side trunk than face it forward . Without sealing off, it was also way quieter! Butt still sealed it off world of a difference !! Every note was louder n it even able to hair trick now . Thats a big 104 Sealed off proper, and a night and day differance. Also, if its a proper seal, from what i understand, there is like zero rattles. In fact, was told thats when you have it done and done right, is when your have zero trunk rattle. I gave up on the build, or i would have gone that route. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
stroupe79 Posted February 7, 2013 Report Posted February 7, 2013 you can make templates with cardboard to accurately cut your panels to seal it off...that way you will be able to use very little expanding foam...I had a box completely sealed forward without using foam at all and it was way louder to add to kylar's comment...if and when its sealed completely forward properly you will have no rattle from the trunk or rear quarter panels... http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup)
SojiaRaggs9000 Posted February 7, 2013 Report Posted February 7, 2013 I have mine firing into the cab. I took some 2.5" painter's tape and taped up the factory carpet area before using any spray foam. Trust me if you everwan t to upgrade or need to take the box out for any reason you'll thank me later lol. It works just the same and seals the same. But it gives you the added feature of being able to remove the foam without damaging the factory carpet. * Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )* Rockford Fosgate Balanced Line Driver * One FULLY LOADED ~ 10" DC m2 XL* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling* MechMan 240a High Output Alternator * KnuKonceptz Krystal Kable RCA Cables* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable* Five Exide Orbital ORB34M Marine 12 Volt Batteries* PowerMaster XS D3100 12 Volt Battery My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
