mav1989 Posted February 10, 2013 Report Share Posted February 10, 2013 The last box I built was only running like 250rms for a cheap daily driver. New car new system planning on running ~1200, ported. Havent decided on the woofer(s) yet. I am thinking of doing a baltic birch box w/ a stained finish. This means all imperfections will show. So, the question. is woodglue and nails from a nail gun good enough to ensure structural integrity or does it truely need to be screwed? Because if its screwed, you have to fill it and it will show through to the finish. Thoughts? Link to comment Share on other sites More sharing options...
WillPwn4Food Posted February 10, 2013 Report Share Posted February 10, 2013 Wood glue every side but the back on. Fiberglass all inside corners/edges. Wood glue the back on. Then reach your arm in the woofer hole and fiberglass the back corners/edges.if you want put metal corner bracing on the inside. Inside can look like ass without having any imperfection visible on the outside. Did this to my 1.5 cuft box for my home theater woofer. Dropped it down a flight and it held together. Figured it could sustain a Woofer if it survived that. Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893 real men dont use fuses Neither do moronsSays the guy with lambo doors on his Ford Taurus. Link to comment Share on other sites More sharing options...
kirill007 Posted February 10, 2013 Report Share Posted February 10, 2013 You don't need to use nails or screws if you have good and enough clamps. Thinking is the root of all problems... You ALWAYS get what you pay for. Link to comment Share on other sites More sharing options...
mav1989 Posted February 10, 2013 Author Report Share Posted February 10, 2013 mmm, never done any fiberglass/resin work before. I n00b. Link to comment Share on other sites More sharing options...
zxsonnyxz Posted February 10, 2013 Report Share Posted February 10, 2013 Listen to Mr. Bond up there. STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback! Link to comment Share on other sites More sharing options...
WillPwn4Food Posted February 10, 2013 Report Share Posted February 10, 2013 Its not hard. Follow the directions and work fast. Put down plastic on the outside of the box so you don't get it on the outside of your box. Use a well ventilated area ad wear gloves you don't mind throwing. Watch a few YouTube videos. I was scared when I did it too. Looked like ass on the inside but it's rock hard. Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893 real men dont use fuses Neither do moronsSays the guy with lambo doors on his Ford Taurus. Link to comment Share on other sites More sharing options...
WillPwn4Food Posted February 10, 2013 Report Share Posted February 10, 2013 Just don't use any brush, mixing bowl, gloves etc. that you want to keep. When it hardens, it's stuck there. Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893 real men dont use fuses Neither do moronsSays the guy with lambo doors on his Ford Taurus. Link to comment Share on other sites More sharing options...
