96 DemoCCord. 150@32hz in a trunk + 3way SQ front stage
The XFL's are crazy on this power... I need a little better electrical. Dropping to 12.8 again. Have to hold the amp back sometimes. It's too much power :)
Nah... I didn't mean that last statement.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Good suggestion on the doors hunter. Still got time to decide. I think I'm gonna try to just swap pro comps for my polks and get some q logic kicks for quickness. Comps will be in during late nov so it will be a last minute thing before my show.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
And if you don't want to screw into the door like I did, I'm sure you could just cover the part of the door with some heavy duty velcro. Like, lay that shit on there. Cover 100% of the surface that the pod will cover. That'll keep it on.
Then some day if you want it off, peel the velcro off. Then use some Goo-Gone or something to get the residual adhesive off the door. Bam.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Who wants to see the video results where my port wall broke off on my first boom cruise?
CT Sounds ftw.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Lol @ this box. Cant wait for the new one. Check it out.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
12.8? I saw 11.3 yesterday
lmfao at the port and Im going to need that 125.4 for my sierra
Used to have a loud truck
2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq
2013 F-150 limited, MPT Tune, leveled on 35"s
yeah im down in the 12.1 starting -11.3 ish at the end of 30 seconds at a stop light. Never seen below 11.1 and that is after trying air forces... lol. But those are all idle voltages. I stay 12.8 ish full tilt, starting around 13.5, then 13.1 then settling at 12.8 after a few bass lines.
Trying to figure out how to get better voltage again. Im thinking i might need OFC everything... maybe a full length ground front to back thats linked to both the front and rear strut towers on the way, and (not gonna happen by TD) DC power 270xp to top it off. maybe switching to XS power after i get all of those things done.
By TD im trying for a all OFC after the rear battery, and ill just be careful with voltage. Hopefully before summer 2014 ill be back in the 13+ volt club.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Also sir. The 125.4 is mine, :D mids and highs are louder just swapping the t600-4 for CT sounds. Even my gf who is car audio illiterate said.... "YEAH........., Thats louder"
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
nice man!! im glad you are happy!! that broken port means you need stronger box!!
the OFC should definetyl help with voltage!! i think once you swap your alt and go to OFC you should be 13 plus. if not, one more battery maybe larger than a group 24 or about the same should hold you up there.
with 2 xs power D3100s i can hold 13-13.2 no clip at the amp for as long as i want on my 2 m3b wired at .7 a piece. when i drop it to .18 they dont like it., 10.xx volts.
but looks good man!!
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Updates coming after class... Anybody interested?
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
  • Who's Online   1 Member, 0 Anonymous, 1045 Guests (See full list)
