96 DemoCCord. 150@32hz in a trunk + 3way SQ front stage
No pics?
I'll post a couple up here shortly. Just seeing who is left on SMD :D
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Im not sure if i started another build log for this. These photos were already in my photo bucket... so we will just post them up along with plenty of new ones.
^ here i called second skin and they hooked me up.
second skin in the doors.
Overkill pro on the door panel
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Time to build the subwoofers...
shortly after
My direct leads
Heatshrink over the copper sleeve and inserted...
Building the box
this one was 33.75 wide x 14.5 tall x 24 deep IIRC. Tuned to about 32 hz with 12.5 ppc.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
out with the old..
taking this out was a pain
the seal has been broken
carpet and all of this crap wire has to go too..
starting over
some second skin and some clean wire routing.
RCA's run.. time to solder the head unit and meters.
luxary liner in... meters and headunit soldered. Ready for input.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
2 runs of welding 2/0
dedicated negative attached at each strut tower incase it wants to take my car or the cable back up to the front. just trying to cover the bases.
slightly later.
time for a 3 way.. and not the fun kind :)
box progress.
looking sexy
carpeted... stained. clear coated. loading subs.
time to make the magic happen..
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
time to start wiring.
proof i actually work on my car
b2 DSP hiding
foamed.
A pillar time..
hold on... money shot of the port.
carpet lines
Now i gotta upload some pics off my phone... so be patient. Some comments would be sweet :)
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
testing of the 3 ways
wrapped the trunk
peep them door panel tweeter plugs :D
how my team feels
Some voice coil wiring.
SPL tape!!
so ill actually type a little bit here. When i first installed the box, my bandwidth increased a great deal.. my peak went down to 32 hz and my new score was a 147.1
Well... Using a bunch of this tape and some testing over the corse of 2 weeks i brought my score from a 147.1 at 32 hz to a 149.2 at 32hz. Then i swapped from a zero.1 to a m4b (3.5k to 5k board) and gained the last .8 db... officially hitting a 150.0db from a trunk at 32hz.
It is an outlaw score... but on the way back we did a windows down headrest score driving and it was between a 145 to 146.5 depending not the frequency.
making some back trim panels.
doing some testing with my DSP
back to the beauty panels...
here you can see my SPL switch... its just a switch to turn off both of my 4 channels during testing. increases my score by about .2db by having the amps off and i don't have to mess up my front stage with 32hz tones.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
  • Who's Online   0 Members, 0 Anonymous, 2882 Guests (See full list)
