Rockford96 Posted February 13, 2013 Report Share Posted February 13, 2013 im planning on building a center console in my truck when it warms up here and was jut looking if there is any tips or tricks im good at wood working i just want it as oem looking as possible basically im just wondering those that have done it is there anything i should be doing or or know before. im not putting subs or anything in it yet my truck has no cup holders so thats the main reason im gonna do it, thanks guys in advance My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu Link to comment Share on other sites More sharing options...
n8ball2013 Posted February 14, 2013 Report Share Posted February 14, 2013 have you looked into oem parts from other trucks or cars to use? THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Rockford96 Posted February 14, 2013 Author Report Share Posted February 14, 2013 No i havent but thats a good idea ill go to a junkyard and see if i can find some buckets thanl you i didnt even think of that My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu Link to comment Share on other sites More sharing options...
Pioneerchuck Posted February 14, 2013 Report Share Posted February 14, 2013 Im not sure what truck you have, but I had a 99 F150 and took the bucket seats out of a 98 expedition and bolted them into my 99 F150. It was a direct fit all I had to do was pull the little rubber plugs out of the holes in the floor and tap some threads for the seat bolts. All you'll need is a good tap/die set and a good ratchet set to do a bench to bucket conversion. As for the console, you can go online and find some used consoles on Ebay and just clean em up and paint them or have them refinished. Link to comment Share on other sites More sharing options...
KillaCam Posted February 14, 2013 Report Share Posted February 14, 2013 Yeah you could find something from another vehicle that would fit. If you build your own you can get a lot more use out of it... Making a spare spot for VM's or a VU-DIN (it can be hard to find a place in the dash for these). Switches/toggles, an EQ. You can put storage space in it to put all your useless receipts in lol. Cup holders... lots of options. Then wrap it with something that matches your dash to look oem. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log Link to comment Share on other sites More sharing options...
Pioneerchuck Posted February 15, 2013 Report Share Posted February 15, 2013 Oh and if you build your own center console, you can take the brackets from the factory console and use them to hold the custom console in place. That's what I'm doing and all I had to do was pull the plugs and tap the holes. Link to comment Share on other sites More sharing options...
Rockford96 Posted February 15, 2013 Author Report Share Posted February 15, 2013 Yeah you could find something from another vehicle that would fit. If you build your own you can get a lot more use out of it... Making a spare spot for VM's or a VU-DIN (it can be hard to find a place in the dash for these). Switches/toggles, an EQ. You can put storage space in it to put all your useless receipts in lol. Cup holders... lots of options. Then wrap it with something that matches your dash to look oem. ya i like the idea of getting one from a diff vechicle but building my own i could definitely have alot more uses for it and use the availiable space better thanks guys for the info and ideas My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu Link to comment Share on other sites More sharing options...
ThreehundredC Posted February 25, 2013 Report Share Posted February 25, 2013 if u get one with the basic shape u can trim the face of it out and mount whatever u need but it wouldnt be to hard to just make two wooden sides and a top Link to comment Share on other sites More sharing options...
