Alright guys, I am looking for some kind of fixed tensioner setup to convert my 2006 silverado with the 5.3L engine to. Reason is that I have installed a triple alt bracket and 2 h.o. alts and just replaced the tensioner, but it still slips with little load on the alternators. If I press the gas and have someone watch the automatic tensioner they can see the tensioner lose ground as the engine speeds up. I know its a long-shot and its alot of belt to tighten but just wondering if anybody knew of something.. thanks
2006 Silverado Ext. Cab
6-15" SSA ZCONS
4th Order Blow-Through
Pioneer AVH-P4200dvd
American Bass VFL 1100.1 12 volt
6 C&D Batteries
2-350A Singer Alternators and Stock Alt
DC Power Triple Alt Kit
MLA Module
3 Runs of 1/0
2 Sets of Boston Acoustics 6.5 Pro Components
Boston Acoustics 2-channel
Lots of Sound Deadener
....Build still in Progress...
slips at idle? i know almost everyone with a multi alt setup gets it at the 1-2 shift.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
thats where its the worst.. it dosent slip at idle, but like i said if you throttle up you can see the tensioner lose ground.. Idk maybe im just being picky about it, but I thought id ask if there was a fixed pulley setup out there anyone knew of.
6-15" SSA ZCONS
6 C&D Batteries
MLA Module
3 Runs of 1/0
if oyu find a way to fix it you'll be rich. you can try a different belt. there are a couple companies taht make better belts but they may not fix it.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
alright, thanks!
6-15" SSA ZCONS
6 C&D Batteries
MLA Module
3 Runs of 1/0
Contact Magnusun, I got a HD tensioner fromt them for my supercharger. With the HO alt and the drag from the charger I have at least as much if not more stress on the belt and I have no slippage with this tensioner.
http://www.magnacharger.com/
805.642.8833
I deal directly with David Gonzales, you can look him up in the company directory when you call. He is a good guy and will shoot you straight.
There are also manual tensioners if you search for supercharger tensioners but I like the HD tensioner, if you want I can take a pic later and post it.
You can always throw an 8 or 10 rip pulley setup on there and you will have zero belt slip with those but you will be into it for about a grand.
This is a writeup on one similar to the one I use:
http://www.performancetrucks.net/forums/forced-induction-159/my-billet-hd-tensioner-486308/
  • Who's Online   0 Members, 0 Anonymous, 490 Guests (See full list)
