barney91 Posted February 14, 2013 Report Posted February 14, 2013 Hey guys I was woundering if a sc31ds optima is good for car audio, if not do you guys know of a good interstate batt that would work for me I'm only running 2K but I plan to go up to 5K, I have 350 amp singer alt P.S. I know someone that works at interstate and I was told I could get them dirty cheap, only reason I want to try them out Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
bdog Posted February 14, 2013 Report Posted February 14, 2013 you dont want any non sealed batteries in your car. ask him if they have any group 31 agm bstteries REP
bdog Posted February 14, 2013 Report Posted February 14, 2013 looks like they do make agm batteries REP
barney91 Posted February 14, 2013 Author Report Posted February 14, 2013 Aren't the optima sealed. And I'm sure they good because they carry marine batterys Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
bdog Posted February 14, 2013 Report Posted February 14, 2013 i have found that spiral batteries are not as good as agm for car audio. i would have bigger voltage drops when useing said spiral. REP
barney91 Posted February 14, 2013 Author Report Posted February 14, 2013 What spiral battery were you using and what did you switch to, because aren't optimas agm Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
Guest Posted February 14, 2013 Report Posted February 14, 2013 todays optima is garbage. dont even bother with them. edit: yes every optima battery is AGM. but dont put regular car batteries inside your car. the fumes will fuck up your brain and can kill you. get AGM batteries only.
Miguels Posted February 14, 2013 Report Posted February 14, 2013 i have had 2 yellow tops and after sitting a car for a week it failed to start then failed to get charged back up.. they was new with only about a month of use so since then i never run optima batteries my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Watch the bass Posted February 14, 2013 Report Posted February 14, 2013 What is dirty cheap. And wasen´t it N8e with a vew Optima´s in his build??? Only 2 K-watt´s and a 350 amp Singer, in principle you are fine with you electrical system for your stereo and the need´s of the car. If you go up to 5 K invest the money and get a XS-Power D7500 http://www.sonicelectronix.com/item_66602_XS-Power-D7500.html than you have the little reserve. Here you can see what special caraudio batt´s does if you put 500 amp´s of strain = 5 K watt´s on them "in the abundance of water, the fool is thirsty" Bob Marley
HHR Ed Posted February 14, 2013 Report Posted February 14, 2013 Optimas are spiral cells. The main point to that design is weight savings. For the footprint they have, they have less lead than standard geometry AGM batts. This makes them lighter but also they have less capacity. So for the same sized batt, you can get way more power from other batts. Also, a few years ago, optima was sold to Johnson control who moved their production from the US to Mexico. Tolerances and quality in materials have diminished and the current product you get is inferior to the older products. Older Optimas could last 10 years. Current models have been known to crap out within a year in many cases. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
