sphinxbccp Posted February 19, 2013 Report Posted February 19, 2013 As I.V said, check and clean mass airflow... My blazer was doing that (not dieing tho) i cleaned the mass airflow and it runs great now, even if it looks clean it might not be. Build log: Click Feedback: http://www.stevemead...xbccp-feedback/ 03 Chevy Blazer - IPad Air 2 - ALPINE Head Unit - 4 DC XL 18s - 2 DC 3.5k - ALPINE TYPE R 5.25 COMP - 3 ALPINE TYPE R 6.5 COMPs - DC 175.4 - DC HO Alt - D3400 - 4 XP3000s - KNU 0ga - 60 SqFt Damp Pro Lots more...
dblovah51 Posted February 21, 2013 Author Report Posted February 21, 2013 aite thanks guys will let yal know the solution when its fixed. 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
Ben Fultz Posted February 21, 2013 Report Posted February 21, 2013 you could also try checking your TPS ( throttle position sensor) They can get a worn or flat spot since they spend 75% of there time in the idle position.
kickass audio Posted February 21, 2013 Report Posted February 21, 2013 I had the same thing but it was a problem with the firmware revision I had flashed for the PCM and ECU. I had all the computers in my truck reprogrammed and flashed to the current revisions and have had 0 problems. The throttle response is way better, the truck shifts better, I only on rare occasions have a little bit of a wait before the truck responds when flooring it and my problem of the truck stalling or choking out is no longer existant. Mine had a lot of things replaced before I updated the computer. For example I had the EGR valve, throttle body, smog pump, spark plugs and fan clutch. Even after all of those were replaced it still was very sluggish and the engine died 3 times and a 4th time it was about to die but recovered. At the time of the software update I had also had my water pump replaced. After updating everything seems perfect. I really think its software related as it acts like the engine is being choked off from the air/fuel mixture. I know other people mentioned but check your MAF sensor. Im 99% sure your TB has one, the envoy's dont. For the 2 total times mine had been "choked" off the engine rpm would drop down to about 200 or 150 and you would see the voltage drop, oil pressure starting to drop (isnt the real oil pressure anyways, FU GM lol), and then I felt a slight shudder, almost like if you were driving in a manual transmission vehicle and shifted incorrectly between gears and then it went back to normal idling at 750rpm and ran fine. The other times I had no notice of it stalling, it never shuddered, made noise or had any of the dummy lights on which was odd because at minimum the check engine, check gauges and battery dummy lights should have illuminated. The software update is pretty costly and though I did get a discount since im a good customer of my mechanics shop it cost $300 for just the software updates. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
