EricDoody95 Posted February 15, 2013 Report Posted February 15, 2013 I was going to get 2 of these, are they any good? 2003 Honda Element Pioneer DEH-9400BT Big 3 XS Power D5100 Sky High CCA (2 Runs 1/0 Gauge) 2 XS Power D3100s 1 DC Audio 3.5k @ 1ohm. 2 DC Level 4's w/ XL Softies Custom Box tuned to 29hz CT Sounds 125.4 2 Sets of CT sounds Meso Components *North East Frequencies*
EricDoody95 Posted February 16, 2013 Author Report Posted February 16, 2013 ? why not buy one good amp? Because i my subs are D2. So i can either wire at 2 ohms, .5 ohms or 8 ohms. i want to run at least 1000RMS to each sub, finding an amp that is 2000RMS @ 2 ohms is gonna be expensive, i have a budget 2003 Honda Element Pioneer DEH-9400BT Big 3 XS Power D5100 Sky High CCA (2 Runs 1/0 Gauge) 2 XS Power D3100s 1 DC Audio 3.5k @ 1ohm. 2 DC Level 4's w/ XL Softies Custom Box tuned to 29hz CT Sounds 125.4 2 Sets of CT sounds Meso Components *North East Frequencies*
Moreno93 Posted February 16, 2013 Report Posted February 16, 2013 had the GLX1000.1 it got a bit warmer then i wanted it to be ( mine goes behind my back seat ) didn't like it so i bought the bigger one, GLX1400.1 was running both at 2 ohms. Much cooler. Same Size too.
EricDoody95 Posted February 16, 2013 Author Report Posted February 16, 2013 had the GLX1000.1 it got a bit warmer then i wanted it to be ( mine goes behind my back seat ) didn't like it so i bought the bigger one, GLX1400.1 was running both at 2 ohms. Much cooler. Same Size too. Budget tho. one gladiator for each sub 2003 Honda Element Pioneer DEH-9400BT Big 3 XS Power D5100 Sky High CCA (2 Runs 1/0 Gauge) 2 XS Power D3100s 1 DC Audio 3.5k @ 1ohm. 2 DC Level 4's w/ XL Softies Custom Box tuned to 29hz CT Sounds 125.4 2 Sets of CT sounds Meso Components *North East Frequencies*
Moreno93 Posted February 16, 2013 Report Posted February 16, 2013 sorry to clearify, it's behind a seat and doesn't get very much air. So i wanted a amp that would stay cool before i put it behind the seat. i mean it'll push them didn't have any problems with it just was personally preference.
Watch the bass Posted February 16, 2013 Report Posted February 16, 2013 The only actual line of trustage from Hifonic´s is the BZR line, the other lines are known for not doin rate. I wouldn´t run a Gladiator amp @ 0.5 Ohm. Get 2 BRZ 1200 http://www.woofersetc.com/c-3-amplifiers.aspx?manufacturerid=34, or with a BRZ 2100 2400 http://www.ebay.com/sch/i.html?_odkw=Gladiator&Channels=Mono&_dcat=18795&Brand=Hifonics&_osacat=18795&_from=R40&_trksid=p2045573.m570.l1313&_nkw=BRZ&_sacat=18795 "in the abundance of water, the fool is thirsty" Bob Marley
EricDoody95 Posted February 16, 2013 Author Report Posted February 16, 2013 The only actual line of trustage from Hifonic´s is the BZR line, the other lines are known for not doin rate. I wouldn´t run a Gladiator amp @ 0.5 Ohm. Get 2 BRZ 1200 http://www.woofersetc.com/c-3-amplifiers.aspx?manufacturerid=34, or with a BRZ 2100 2400 http://www.ebay.com/sch/i.html?_odkw=Gladiator&Channels=Mono&_dcat=18795&Brand=Hifonics&_osacat=18795&_from=R40&_trksid=p2045573.m570.l1313&_nkw=BRZ&_sacat=18795 I planned on running both of them at 1 ohm to each sub, because i have a budget. I want to send at LEAST 1000RMS to each sub and i cant run at 1 ohm if im going to be using a single amp. 2003 Honda Element Pioneer DEH-9400BT Big 3 XS Power D5100 Sky High CCA (2 Runs 1/0 Gauge) 2 XS Power D3100s 1 DC Audio 3.5k @ 1ohm. 2 DC Level 4's w/ XL Softies Custom Box tuned to 29hz CT Sounds 125.4 2 Sets of CT sounds Meso Components *North East Frequencies*
Watch the bass Posted February 16, 2013 Report Posted February 16, 2013 The only actual line of trustage from Hifonic´s is the BZR line, the other lines are known for not doin rate. I wouldn´t run a Gladiator amp @ 0.5 Ohm. Get 2 BRZ 1200 http://www.woofersetc.com/c-3-amplifiers.aspx?manufacturerid=34, or with a BRZ 2100 2400 http://www.ebay.com/sch/i.html?_odkw=Gladiator&Channels=Mono&_dcat=18795&Brand=Hifonics&_osacat=18795&_from=R40&_trksid=p2045573.m570.l1313&_nkw=BRZ&_sacat=18795 I planned on running both of them at 1 ohm to each sub, because i have a budget. I want to send at LEAST 1000RMS to each sub and i cant run at 1 ohm if im going to be using a single amp. I understand that, but the BRZ is not so much over the GLX line, cheapest offer of the GLX 1000 i found was 160. Surly you want get 1000 watt RMS per sub from the Gladiator series. Little cheaper offer http://www.onlinecarstereo.com/CarAudio/p_23922_Hifonics_BRZ12001D.aspx "in the abundance of water, the fool is thirsty" Bob Marley
Guest Posted February 16, 2013 Report Posted February 16, 2013 BRZ is the only decent line hifonics offers nowadays. everything else (aside from some XXV) is trash.
