Misc. Sealed off trunk - '01Stratus *Gutted*
New coils will smell...I would make sure it isn't clipping. Good subs can be burnt up by 600 dirty watts because of clipping with dirty songs or too much gain. I am pushin 2500-3000 watts easily to 1500 watts subs because it is clean power.
Yeah gains are set with dd.1 and crossovers set with cc.1. All is good ;) deck doesn't clip at all with everything set to flat. Sub amp is tuned to -5dB.
That makes me feel a bit better now about the coils.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
This.... I ran my VVX 12's (600rms) on my 2500. Meaning they were each seeing double RMS. they had a crispy clean signal the whole time and always feed clean music.... DD1 set on that was -5db. After about 30 minutes they would get warm but not stinky at all. Once I fed them a (SLIGHT) clipped signal for 6 minutes just to see and I got a nice poof of smoke out of my box and a nasty smell.
Clean signal is key.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
That's great to know! Thanks.
Some other minor updates.
Washed the car today. Sprayed extra amounts of water around the antenna and the brake light. No water would come through.
Current favorite song to demo is In this Ho - decaf'd. Freaking love the bass that leads up to the drop. Makes people think that the system is decently loud, then that low hits. Insane.
where'd you get the carpet from?
parts express. it was sold by __yard x 48inches. I ended up using 3 yards.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-764
Well tomorrow I hope to finish off everything. The main thing being the rear beauty panels.
I still have not been able to locate that damn leak. I got pretty pissed and took a power washer and put the tip in it for washing cars, and sprayed all over and around the antenna and tail lights. Wouldn't leak. I have a bad feeling it might be the body work under neath. Because there was only water there once I drove the car and there was water on the roads. So I might just caulk all the joints on the inside of the car. Not sure yet.
Will also be tackling my bit of amp vibration I have. Snowdrifter gave me something to think about when mounting the amps. I believe the head of the screw was to tight against the amp causing the amp to vibrate. So I will be trying to make the screws snug, but not tight like there where before.
I'm not really even sure why I have vibration. My box doesn't actually vibrate itself. I put a little 1lb weight on the box and then a quarter and they didn't bounce or anything. I understand I have carpeting, but still.
The last thing to do is clean up my wiring. Not much to clean up but there is a bit.
I have also got used to the bass already.... Saw some hdc3 12's for sale. Was so tempted to pick those up and another 2200 :peepwall:
Really sorry for the quality of pictures. The camera I normally take pictures was MIA. Drove 20 miles to my moms house just to look for the dang thing. Can't find it. So I had to resort to my ipod. I promise some super high quality pics in the near future :)
Some final touches.
I put the carpet covers back over the wheel wells. That was a pita to say the least.
Here's how the lower section looks like.
Overview
The beauty panel is 100% cut out and fitting
Wrapped in carpet. Waiting for them to dry.
I think I found the damn leak. It was the under body. Not sure why it is seeping in. But I caulked the hell outta that corner.
Here is how the beauty panel will be supported. There will be another one on the other side of the fuse holder.
Looks amazing man!
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
Well enough of those shitty pics. Here's all of the good ones I promised. Thanks for stickin' through the build everyone!
Here is the final outcome of the beauty panel :D
  • Who's Online   0 Members, 0 Anonymous, 611 Guests (See full list)
