Misc. Sealed off trunk - '01Stratus *Gutted*
Really nice job on your first build. Mad props...lol. Good luck on SOTM
Thanks!
once the mirror falls off, it seems like no matter what you do they never stay up very good after that
well crap.. I have sort of gotten used to not having it. Haven't had the time or weather to put it back up. Might just leave it off for now.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Good luck on SOTM!
I only have 1 suggestion. If you get time, you should make a beauty panel of some sort to hide the wiring between the amps :)
Otherwise I think your build looks great :D Keep up the great work!
My Build Log
Heros get remembered, but legends never die.
Good luck on SOTM!
Thanks! Ha my "original" plan when I had no clue how everything would lay out consisted of those panels. I thought that the amps wouldn't come out to the end, and that I would have 3 inches on either side. I was gonna make a panel to hide 100% of the wiring. I honestly was pretty lucky that everything layed out fairly nice, even thought I made no prior measurements other than for the battery and the box height/width.
Anyways I still might eventually make another beauty panel, or at least something to clean the wiring up a bit more. Maybe some huge 2" techflex, if they make that lol.
lol cool, sounds good :D I'll be keeping my eye on this build!
My Build Log
I got the same voltmeter :) how did u go about mounting it down?
I used some double sided trim tape. It hasn't budged a bit.
I can't catch a break with this dang mirror. It held on for a good two weeks before popping off again. Doesn't like the lows. She is probably just gonna stay off this time. But I sure am gonna miss 'er. If I could buy the mirror glue in bulk, I wouldn't mind stickin it up every few weeks. But not at $4 each time.
The song it popped off on this time was In the Zone.
How about getting a roof mounted mirror? I mean you will have to do moding of course, don't know if you're that concerned about it or not.
95 Acura Integra - 5-speed
Pioneer FH-X700BT
(2) Rockford Fosgate 12" P3
AQ1200d
Rockford Fosgate P1652-S 6.5" components
Rockford Fosgate P1572 5x7"
Rockford Fosgate R400.4
95 Integra Build Here
93 EJ2 Build Here
I don't know about your civic but my accord has a roof mounted mirror :)
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   0 Members, 0 Anonymous, 679 Guests (See full list)
