Misc. Sealed off trunk - '01Stratus *Gutted*
Make sure you give a good sanding and wear good breathing protection.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
So I was trying to figure out how to wire up the subs. I already have 8ga speaker wire ran into the box with ring terminals. Well stupid me I made the left side really short, hardly enough to touch the bottom of the box. So I figured I would make some terminals up, and then make 4 more sets of 8 ga speaker wire with ring terminals on the end and mount everything to that terminal block. Subs only accept 10ga. so I'll probably just trim a bit off.
Here's the terminal I made.
I'll get final pictures of the bracing with the fiberglass on it., and the terminals mounted in the box. as far as glassing goes, I'm done in the box. I'm going to coat the t nuts with a bit of super glue so they won't back out. and I'll be getting different bolts to mount the subs with. as some of you could tell in a few pictures, the ones I had rusted a bit.
Oh, I still need to see if the hds3 will mount up to the sdc2.5 mounting holes... or if it fits in the hole. really don't feel like making the whole bigger.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Good job man. I got a 2000 Dodge Stratus ES myself.
Well I got everything a little more ready to install the subs. I took off the tape off from the terminals -- which was hella fun. Not really. Got the nuts/ washers on and in the order I want. Super glued the back of the t nuts. and took out the cardboard piece. I also clean up some of the random fiberglass messes around and about. (random hairs, crap on the wires, etc) I could install them tonight. But I don't have the ambition lol. Plus I need to trim the 8ga speaker wire a bit to fit the 10ga speaker push terminals. Might have them in tomorrow. Depends how long I stay at this one audio shop after class. He wanted to see the smd tools in action.
Here is a few final pics before subs go in.
good job!
how does it sound now ?? is there a noticeable difference ?
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
subs aren't in yet lol. I'll let all you know once they're in. Honestly, my main goal was to kill amp vibration. I just needed a motivator to pull the subs and do it. Which is why I got the Hds300's haha
  • Who's Online   0 Members, 0 Anonymous, 2479 Guests (See full list)
