fox_racin4 Posted February 23, 2013 Report Posted February 23, 2013 What style? ( theres 3 of them... 1 is a 12v amo, one is 16v capable amd anoter has SINGLE outputs) Some will work fine at 1ohm Ohther not so much. Try swapping speaker leads to the other amp and try it again. 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Awhitewookie Posted February 23, 2013 Author Report Posted February 23, 2013 What style? ( theres 3 of them... 1 is a 12v amo, one is 16v capable amd anoter has SINGLE outputs) Some will work fine at 1ohm Ohther not so much. Try swapping speaker leads to the other amp and try it again. This one. http://www.audiopipe.com/products/amplifiers/ap/ap-30001d.html MY BUILD 1998 Ford Explorer 2dr sport 1/0 Big 3 1/0 everything Alpine cda-9884 Crescendo CZ components (2) Crescendo bc2000's (2) Jolt 150ah (2) Yellow top optimas (1) Juicebox black cherry addition (1) Mechman 270 avbm miss my bc5500 and (4) 15's You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
n8ball2013 Posted February 23, 2013 Report Posted February 23, 2013 try switching speaker leads to the amps or the rcas like said. see if its the same amp THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
teamace24 Posted February 23, 2013 Report Posted February 23, 2013 What ohms are the subs and coil numbers. How many? 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Guest Posted February 23, 2013 Report Posted February 23, 2013 those amps are only stable down to 2 ohms. 1 ohm is basically making each ap1500 work at .5 ohms. i'm willing to bet thats why its protecting. They are correctly wired to 1ohm the amps are stable down to 2 ohms. it says so right in the picture. you just said you are wired to 1 ohm. that is likely your problem.
Awhitewookie Posted February 23, 2013 Author Report Posted February 23, 2013 those amps are only stable down to 2 ohms. 1 ohm is basically making each ap1500 work at .5 ohms. i'm willing to bet thats why its protecting. They are correctly wired to 1ohm the amps are stable down to 2 ohms. it says so right in the picture. you just said you are wired to 1 ohm. that is likely your problem. Sorry I am trying to follow what you mean. I still fully disagree. Each sub has its own ap1500 which shows is stable at 1ohm as in the picture. Nothing is bridged. Each channel is at 1ohm. I hope i dont come across as rude, i have a ton of respect for you kranny MY BUILD 1998 Ford Explorer 2dr sport 1/0 Big 3 1/0 everything Alpine cda-9884 Crescendo CZ components (2) Crescendo bc2000's (2) Jolt 150ah (2) Yellow top optimas (1) Juicebox black cherry addition (1) Mechman 270 avbm miss my bc5500 and (4) 15's You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
teamace24 Posted February 23, 2013 Report Posted February 23, 2013 Bridged can go down to only 2 ohm but it can go 1 ohm if each channel sees a 1 ohm load. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
teamace24 Posted February 23, 2013 Report Posted February 23, 2013 Dmm each sub at the amp make sure its right ohms. Or gain set to high or ground problem. Maybe rca problem too. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Awhitewookie Posted February 23, 2013 Author Report Posted February 23, 2013 I checked them and they are all correctly at 1ohm. Gains are barely at 1/4. Grounds are all 0 gauge on the frame and body bolted, and shaved pant off. What ohms are the subs and coil numbers. How many? Subs are quad 1 ohm coils, correctly wired to 1ohm each. MY BUILD 1998 Ford Explorer 2dr sport 1/0 Big 3 1/0 everything Alpine cda-9884 Crescendo CZ components (2) Crescendo bc2000's (2) Jolt 150ah (2) Yellow top optimas (1) Juicebox black cherry addition (1) Mechman 270 avbm miss my bc5500 and (4) 15's You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Guest Posted February 23, 2013 Report Posted February 23, 2013 i always thought that the ap3000's internally bridged themselves. unless there are different generations that do different things. i may be wrong about it all then. teamace has a point. DMM the speaker terminals on the amp to see the resistance. that will tell you for sure. edit: i always heard that it was 2 ap1500's strapped internally. thats why i said that.
