what would make my setup better
villarob713
so you know, you should spend on the higher end of the price spectrum. higher quality products won't leave you stranded, or with bad batteries
you won't fit 4 twelves in a corolla. stick with 2. fitting ten pounds of shit in a 5 pound bag will likely make you quieter than with proper fitting woofers that will have room to breathe
depends on how much you have to spend and how much power you have available to throw at them
value for money idd recommend
1-2k of power, 2x sa12 ($195ea)
1500-3k, 3 or 4x sa10 ($185ea)
3-4k, 2x zv3 12 ($460ea)
4-7k, 3 or 4x zv3 10($450ea)
but if you looking for some serious bass on a big budget look at the e series
the new e8 are an awesome product
http://www.emfcaraudio.com/sundown-audio-e8v3-dual-4/
Thoes 15 do well for what they are
Idd stick with the 2 you have
And when cash is better get a nice 2k 1ohm stable amp
But first
Install the aftermarket H/U you have
And install a second battery or at least a better up front, then add a second
Do the Big 3 if you haven't already
Check you voltage drop at full tilt and then from that add a alt if needed
Don't east your money on a cap unless its a bat/cap and even then I still would buy one
So upgrades in this order
H/U as u have already
Big 3 if haven't already
Good batt up front + 2nd batt
New box built to what u want to achive
1ohm stable 2k amp(something decent)
Then and only then if still not happy add another sub of new/different subs
Thanks bud ima try that
Thinking about getting 2 sa12s
Before you forget all that, fit first your electrical system, your CVX can be loud and from the sound ok in a proper box.
Here a nice offer of AGM batt´s. if you havent a AGM batt up front you need one there too http://www.stevemeadedesigns.com/board/topic/144556-dont-seem-like-a-bad-deal/ and do the Big 3 in 0/1 gauge.
"in the abundance of water, the fool is thirsty" Bob Marley
Was to quick on the post button, you don´t tell what line of Hifonic´s do you have, BRZ line is the only trustfull line from Hifonic´s in the moment, if it a other one they don´t do rated
but they don´t get badder from this.
A corolla? Get 2 beast 10's on either a aq3500.1, bc3500 or dc3.5k.
Used to have a loud truck
  • Who's Online   0 Members, 0 Anonymous, 1371 Guests (See full list)
