TrunkMuzik Posted February 24, 2013 Author Report Posted February 24, 2013 Ok, so Kicker is out. Pair of Sundown E12s or a single FI X15 are my two top choices right now Without music, life would be an error
Carbon Posted February 24, 2013 Report Posted February 24, 2013 Ok, so Kicker is out. Pair of Sundown E12s or a single FI X15 are my two top choices right now any thoughts on either? what would be louder? Careful, dont let this turn in to a vs thread.
Carbon Posted February 24, 2013 Report Posted February 24, 2013 Sundowns are great, I personally own Fi which is also great.
TrunkMuzik Posted February 24, 2013 Author Report Posted February 24, 2013 Sundowns are great, I personally own Fi which is also great. Well that doesnt narrow anything down lol Without music, life would be an error
bighossf150 Posted February 24, 2013 Report Posted February 24, 2013 Either a fi q or aa havoc. Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
Watch the bass Posted February 24, 2013 Report Posted February 24, 2013 Ok, so Kicker is out. Pair of Sundown E12s or a single FI X15 are my two top choices right now any thoughts on either? what would be louder? Careful, dont let this turn in to a vs thread. 2 12 more conearea! Or go 2 SD 2, you underpower them a little bit with your amp, but you can control them if you build a bigger box than threw the specs. "in the abundance of water, the fool is thirsty" Bob Marley
Swordlordboy1234 Posted February 24, 2013 Report Posted February 24, 2013 Careful OP. I'd edit that comment really quick. Cone area is king and I've herd SA's get loud as balls. Check into 2 SA 10's? 12's? If you can't do SA then I'd go anything FI. Can't go wrong with either My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
TrunkMuzik Posted February 24, 2013 Author Report Posted February 24, 2013 Ok, so Kicker is out. Pair of Sundown E12s or a single FI X15 are my two top choices right now any thoughts on either? what would be louder? Careful, dont let this turn in to a vs thread. 2 12 more conearea! Or go 2 SD 2, you underpower them a little bit with your amp, but you can control them if you build a bigger box than threw the specs. but does more cone always mean louder when setup the same? Without music, life would be an error
Swordlordboy1234 Posted February 24, 2013 Report Posted February 24, 2013 Ok, so Kicker is out. Pair of Sundown E12s or a single FI X15 are my two top choices right now any thoughts on either? what would be louder? Careful, dont let this turn in to a vs thread. 2 12 more conearea! Or go 2 SD 2, you underpower them a little bit with your amp, but you can control them if you build a bigger box than threw the specs.but does more cone always mean louder when setup the same? Careful you must be when wording things.... The ban hammer knows all. Lol Cone area helps the most in getting loud but nothing replaces box building skills. If your not pro at boxes stick with cone area My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
