I let my S3 charge over night and it keeps up the whole day.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
well I don't have a problem with the battery life. 1 of the first apps that I had downloaded was Juice Defender, I can get my phone to last a day and a half with moderate usage. I have actually done the research and iPhones have a hell of a lot worse battery life than that galaxy s3.
haha. okay :] not that my ipad mini lasts 15 hours on cellular or nothing (usage) total about 2 days.
my girlfriends htc one X has terrible battery life.. lasts about 5-6 hours.
it does depend on screen brightness use of wifi, LTE, location.. blah blah etc.. but still.
i have a great test. turn auto brightness on in a room where the light is off, set the iphone 5 next to the s3.
the trick is, auto brightness on the android OS is flawed, the screen bightness is extremely way to fucking god damn bright in the dark.
depends how you test it.
im not going to argue with someone who doesnt do actual notable tests and instead does his own "research" in his own environment and not a controlled one.
instead i rather look here:
Battery
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
battery life is shortened by how many full discharges and cycles it goes through. kepping it plugged in and at 100% as much as you can will lenghten the life of your battery. the more you discharge and recharge your bat, the faster it will use up all of its life.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
do you kill your phones battery alot?
I've never killed a battery. Also, I never use the auto brightness, I adjust the brightness as I see fit. If im just playing some music while outside, I will leave it at minimum, if im inside, minimum. Only time it's on higher is if I am actually doing something on it, but once I am done, I turn it back down.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
