engine knocking like crazy. do i have a claim?
Same thing happened to my Honda when i bought it. It is normal, until it gets warmed up. Then all hell breaks loose. Eating water / coolant. Shaking, running on 2/4 cylinders. Just to find out, when they did it, they didn't torque all the head bolts down, leading to a blown head gasket, and 1 1/2 steam cleaned pistons LOL.
I can't exactly answer the driving part, each vehicle is different. We drove my car across town with a blown head gasket, on only water. Sooo. If you can afford, have it towed. Will save you troubles, cause if you drive it, and it over heats, thats more shit you gotta replace.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
i mean a misfire is one thing. a bad gasket or block is quite another..
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Edit: reread your post.
a misfire could have occured due to a loss in compression. ie blown gasket.
regardless a misfire is not gonna cause youre coolant temperature to skyrocket.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
i kinda gotta figure this out on the fly.. like bright and early tom am. so idk what to do.. and if it is a blown gasket what will it run you think? I know its a labor intensive job, but honestly the car isnt worth a 2500 repair..
Setup:
Xs D3400/ Xs XP3000
it depends.. each car is different. if you look up the labor time involved in a job like that for your car you can probably get a good idea. some cars could only take 5 hours some could take 12
if you can find out the time then just multiply that by the labor rates at a shop. youll have somewhat an idea what itll cost to replace a 30 dollar part
ok well thanks for the help. I appreciate it.
Setup:
Xs D3400/ Xs XP3000
good luck. id check around the heads and see if youre leaking anything at all.. its a long shot because headgaskets dont normally blow like that.. most of the time its a crack into a cylinder. but if you get lucky at least youll know for sure.
to check for coolant leaks use baby powder around a suspected area and if the baby powder is wet or is removed by the coolant youll localize the leak.
i mean ill just try to find a shop tom morning. either it wont be too bad or ill be looking for a cheap set of wheels.. praying for the former
Setup:
Xs D3400/ Xs XP3000
http://www.amazon.com/Bars-Leaks-1111-Head-Gasket/dp/B0036VRQ70/ref=sr_1_1?ie=UTF8&qid=1362123659&sr=8-1&keywords=head+gasket
If it is a head gasket and you are thinking of junking it anyways, I would try this. I've heard really good things about it and bad things about it but its worth a try as a last resort.
Here's another one, not sure on the difference..
http://www.amazon.com/BlueDevil-Pour-N-Go-Head-Gasket-Sealer/dp/B004500M8G/ref=sr_1_10?ie=UTF8&qid=1362123659&sr=8-10&keywords=head+gasket
2012 Jeep Wrangler 3.6 W/ 6 Speed
Build Log
2011 Ford F-150 SVT Raptor 6.2
Build Log
YouTube
get a compression tester, solve the mystery in about 30 minutes.
Hammerdown... 1%
