Amp constantly going into protect
Dylan Mohammed
Does it play the sound of the songs you are putting to it or just a constant sound? I had a friend who had an amp that had similar problems as in he would turn it on it would light up power then go to protect after about 5 seconds but he never did get anything to play through it. He even put in new mosfets and no go. So if its worth it I would have someone look at it. Or I would just try to get your money back for it. Check your grounds first thing make sure its on bare metal and not a seat blot or something like that. Sand your body down and attach as close as possible to the amp.
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
CA Auto/ Electric Big 3
Xs power d680 in parallel with new group 65 stocker
Soon to come another d680
Rockford Punch 6x8 3 ways in the front, Rockford Punch Pro 6.5s in the back
Soon to come Pioneers all around
Focal Solid 4 Speaker Amp
Kenwood KDC-X896
Memphis Line Driver
My build log: http://www.stevemeadedesigns.com/board/topic/160368-03-f150-king-ranch/
Youtube: https://www.youtube.com/user/LabAudio502?feature=mhee
And also did you buy it new?
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
Kenwood KDC-X896
Memphis Line Driver
whats the ohm load at the amp?
diffective out of the box? wouldnt be the first time an RE amp was bad out of the box.
GROUND.... CHECK GROUND LIKE MENTIONED ABOVE... (yes caps were on for a reason)
What does your ground consist of? pics..... explain please
I love my staffie :good:
So anti FACEBOOK it isn't even funny
i run an re dts 500.2 and it works like a boss on my sundown comps. loud and clear never had so much as a hiccup out of it. id double check everything and if its still a no go then just return it. after all re is not what they used to be but i guess every company has some failure rate.. bad luck perhaps
out of 32 reviews all but one are 5 stars pretty solid. So id say the QC is decent. you might just be that 1/32 :/
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
It is probably the ground then the internals and all should be fine. Once you are sure that the ground is solid and if it still does not work it probably is bad. But like I said probably the ground.
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
Kenwood KDC-X896
Memphis Line Driver
  • Who's Online   0 Members, 0 Anonymous, 1042 Guests (See full list)
