standardcabspl Posted March 5, 2013 Report Posted March 5, 2013 i mean what are you running, kind of a wierd question to ask usually when people dive into thousands on amps they have an idea on electrical not to be offensive is it a daily or are you just short burping it? Good lord sweet baby Jesus. Did you read the thread at all? Bagged 1993 nissan hardbody
fox_racin4 Posted March 5, 2013 Report Posted March 5, 2013 Also, Are they 12v or 18v amps 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Piggi3 Posted March 5, 2013 Author Report Posted March 5, 2013 I'm not dropping to 11volts I have 8 2150s and 2 mechman 270alts. And have 4 dc lvl5 15s in a 3:1 4th order. And have it at .5 ohm with no problems. Except box rise goes to 3 ohms.
CW06Silvy Posted March 5, 2013 Report Posted March 5, 2013 I have debated this idea.. im curious for the answer..lol 2006 Silverado Ext. Cab 6-15" SSA ZCONS 4th Order Blow-Through Pioneer AVH-P4200dvd American Bass VFL 1100.1 12 volt 6 C&D Batteries 2-350A Singer Alternators and Stock Alt DC Power Triple Alt Kit MLA Module 3 Runs of 1/0 2 Sets of Boston Acoustics 6.5 Pro Components Boston Acoustics 2-channel Lots of Sound Deadener ....Build still in Progress...
SnowDrifter Posted March 5, 2013 Report Posted March 5, 2013 I'm not dropping to 11volts I have 8 2150s and 2 mechman 270alts. And have 4 dc lvl5 15s in a 3:1 4th order. And have it at .5 ohm with no problems. Except box rise goes to 3 ohms. 3 ohms at what frequency? My box rise can go from either rising to 1 ohm, or rising to 4 ohms depending on what frequency I play. You need to start clamping every frequency and make a graph of your rise. From 10hz up to 100hz, just to be safe ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
fox_racin4 Posted March 5, 2013 Report Posted March 5, 2013 The 18v amps will protect a little higher voltage IIRC I ran 2 12v and 1 18v but they would protect from not enough rise ( was always a diff amp, not the same one) 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Piggi3 Posted March 5, 2013 Author Report Posted March 5, 2013 I'm not dropping to 11volts I have 8 2150s and 2 mechman 270alts. And have 4 dc lvl5 15s in a 3:1 4th order. And have it at .5 ohm with no problems. Except box rise goes to 3 ohms.3 ohms at what frequency? My box rise can go from either rising to 1 ohm, or rising to 4 ohms depending on what frequency I play.You need to start clamping every frequency and make a graph of your rise. From 10hz up to 100hz, just to be safe Ok will do that. I clamped from 40-54 and got about even results. All go lower
fox_racin4 Posted March 5, 2013 Report Posted March 5, 2013 Youll more then likely make more power around 30hz 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
