SnowDrifter Posted March 5, 2013 Report Posted March 5, 2013 I'm not dropping to 11volts I have 8 2150s and 2 mechman 270alts. And have 4 dc lvl5 15s in a 3:1 4th order. And have it at .5 ohm with no problems. Except box rise goes to 3 ohms.3 ohms at what frequency? My box rise can go from either rising to 1 ohm, or rising to 4 ohms depending on what frequency I play.You need to start clamping every frequency and make a graph of your rise. From 10hz up to 100hz, just to be safe Ok will do that. I clamped from 40-54 and got about even results. All go lower Yeah dude. You need to go over EVERY frequency you have the slightest possibility of playing. And even still - just because you have enough rise to go at .25 per amp on a tone doesn't mean you can do it on music. This will give you a starting point, but you will need to be the one that makes the decision to risk your equipment. See my signature as to why - theory and reality are two different things ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
corona_jeff Posted March 5, 2013 Report Posted March 5, 2013 Well I hope you got large pockets, I made the mistake of trying .7 strapped on those amps. My electrical is strong, never below 13v. Amps lasted 2 shows before the popped. FYI it's 500.00 per amp to rebuild those.
Azagtoth502 Posted March 5, 2013 Report Posted March 5, 2013 pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
Piggi3 Posted March 6, 2013 Author Report Posted March 6, 2013 Tell me this would it be worth to put a secong 1100.1 at 2ohm with my 6x box rise or not.
fox_racin4 Posted March 6, 2013 Report Posted March 6, 2013 Can you strap them at 2ohm? 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
