two subs two amps single chamber box?
ZAPCO209
How can i make it work i want to run two obsidian 18s in a common chamber ported box and two zapco recerence 1000. How can i avoid phase issues
THE DRIVING FORCE
Gain match with a DMM and make sure your crossovers are set as-close-as-possible too
Or if the amps are strappable, that is always an option
basically this, in a nutshell.
dont think that gain matching means you put the gain knobs at the same position. it doesn't work like that. you need a dmm to do it properly.
What about a CC-1 I got a CC-1 says it gain matchs. Got the same problem as OP but I think I'm going to be good...Just wanna check
Skar Audio SDR 10" x2 (Sealed Box)
Skar Audio 1500.1D (1 Ohm) x1
Skar Audio TX525c (Front with dash tweeter) x1
Kenwood Excelon KFC-X173 (Rear Coax) x1
JL Audio 360.4 (Mids & Highs Amp) x1
DEH80-PRS
XS Power d3400
Singer Alternator 275A
98 Jeep TJ 4.0 5 Speed
Yup, that should do it for you. Make sure you gain match using the "quieter" of the 2 amps as your reference. And make sure the crossovers match too. Tony D'Amore had a cool post about that, saying that having the crossovers slightly different will cause the phase of the 2 amps to differ from one another - causing cancellation and losing some output
  • Who's Online   0 Members, 0 Anonymous, 1095 Guests (See full list)
