Kicker s15l7 box for music
beau123
Does anyone knows the best box design musical sounding for an l7?
who can calculate one for me i want it ported.(in cm please)
i listen to almost everything exept hardstyle hardcore and shit like that.
i know this is'nt a soundquality woofer but i know you can get great sound out of it.
what i have know as a design is 110 liters (without bracing sub and port) with the original port 6,4CM wide 41 cm high and 50 cm long
i hope that somebody has a better one.
I had mine in 7net 90sq" of port
That sub needs a lot of space as its like an 18" in cone area
Post some more info
Car?
Max measurements in all directions
Out of that what u would like to work within
Amp
Elect system
What u want to achieve with it
Post some more info
Car?
Amp
Elect system
The car is a Vauxhall/Opel Astra G sport hatchback 1.6 16v (a german car)
max measurements 90cm wide and 60 cm deep how high it is is no problem
i like it smaller so ik can also put luggage in my trunk
The amp is an kicker 06 ZX 2500.1
Electrical system is almost standard.
120 amp alternateor and 2 Exide Maxxima one in the front and one in the back.
50mm/0/1 gauge wires front to back power and ground.
and if you want to know i have a pioneer 6400bt headunit
steg k2.02 speaker amp foor my doors.
and a audio system xion component set in the doors
i want to play some loud and clear music with it.
It's not rated at 1000rms port only 1000rms sealed
It rated at 750rms ported
What coil config do you have
Because I hope it's d2 so you run at 4ohm final on that amp
it is a dual 4 ohm so the load is 2 ohm.
and i am really careful on the gain and i use a dd1.
and mine is now in a closed enclosure the biggest one in the book first it was playing on the steg but i wanted more power.
a friend of mine have one 12 inch l7 dual 4 ohm also on a 2500.1 and he has it like 4 years now.
and it still works!
I said "up to" 1,000 wrms. ;)
Watch what you're doing with the amp you have for a single 15"L7. The sub is rated up to 1,000wrms.
i read something about that they are power hungry so i spended a little more money on it.
and i think that the amp never reaches 2500 watts on music.
the guy that sells this stuff in holland said that this is a great combination for loud music.
and when i wanted something heavier i can trade it for a dual 2 ohm version and buy a second one.
but in this small car this is enough the only thing is i miss a lot of bass in a sealed enclosure.
If it was me I would have got 2 x 12" d2
It's nilly 30% more cone and will handle that 2500 like a champ after rise
And I bet your birth sheet says that, that amp is like 2800-3k at14.4
  • Who's Online   0 Members, 0 Anonymous, 1386 Guests (See full list)
