96 impala ss temp sound system
350a.. dont need that many but its always better to have more
I'm a dumbass. the title of the thread states the rating. DUH!!!!! I went full retard on that:)
And you cant go wrong going bigger. A bigger alt also allows for electric fans :)
  • 1 month later...
having issues with my singer alt.. after it warms up it fails to charge at idle. keeping me at 12.8 and even 12.5 after sitting at a red light for a while. at idle the alternator is making noises as if it was under load.. the engine idles at 700 rpm so i dont think thats the issue
after checking i found that the 4 gauge wire was hot near the alternator... did a quick upgrade and after an hour its charging at 14.0 at idle and 13.7 with AC and lights on. could be that the alt cooled off a bit so its charging like normal.. i put the battery on the charger and will see how upgrading the wire helps
10156168_676932002343732_150867832891190
10256829_676932045677061_350832693285578
10420016_676932062343726_693300677990346
damn sky high wont even fit in its own lug.. crimped it a bit more guys, dont think i left it like that
10405408_676932075677058_636514207991091
10322760_676932135677052_679464548927464
10383016_676932152343717_390593269119912
Did you order the 1/0 lugs? I didn't have any trouble with the 2/0 and the 2/0 lugs.
Build looks great! Glad to hear that you got the charging issue figured out.
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
i got the 2/0 lugs.. must be because i couldnt find my cutter and used wire cutters and messed the ends up.. i done it before and didnt have an issue but then again i soldered and the heat could have expanded the lug making it easy.. today i only used the crimper
  • 5 months later...
  • Who's Online   0 Members, 0 Anonymous, 1327 Guests (See full list)
