does anyone know how to use the dd1 with a pre amp eq (audiocontrol three.2)
2011 Impala
pioneer headunit
rockford fosgate rca's
audio control three.2
rockford fosgates T165&T1692
2 re audio sxx 15's
hifonics brz24001.d
crunch 1400.4
audio technix 10ga speaker wire & 0 ga power n ground
Use the 0db track. Probe the deck and find its maximum non distorted output. Say its 45/50. Leave it at 45 (and on the same 0db track) and then probe the processor (three.2). Leave it flat for now. Turn up the master volume on the processor until you see the distortion light come on. Leave it on that spot and take a note of it. More than likely, it wont distort even all the way up. If it doesn't, leave it all the way up and then move on to the amps. Use -5 or -10 gain overlap tracks at the amplifiers. For most, -5 on mids/highs and -10 on bass works. That's up to you, read the manual and decide. Now you can adjust your eq settings back to where you want them on the processor and amp's on board x-overs. Its pretty easy process. :)
Follow my Tweet (Twitter)
nvm... Steve explained it way better than me..
Edited by OrzechNJ
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
i have experience in the subject. LOL :D
Thanks alot Steve
2011 Impala
pioneer headunit
2 re audio sxx 15's
hifonics brz24001.d
crunch 1400.4
Is it also true that once that it all done you can only EQ down not up?
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
no, you can go up if you want. But of course, EQin'g is about cutting anywhere you can and only boosting very slightly. It's never a good idea to boost a frequency too much. I can tell you this, starting out flat on the EQ, just using the DD-1, your system should already sound better and you will find yourself not wanting to boost the shit out of the frequencies like you used to. No drawing smiley faces with the sliders anymore :D
I leave mine flat and it sounds great but I'm no SQ audio file guy. I was just trying to learn a bit incase I ever did decide to get an EQ with more then 5 bands
Edit : anyone that I've tuned their system with the DD1 bass boost off and flat EQ's and they always questioned me until they heard it. LOL
Edited by Swordlordboy1234
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
all i want is hard hitting bass and clear mids and highs that i can hear over my bass rite now im stuck on where to set my bass amp frequencies and my mids and highs frequencies im still doing research to find a good spot lol
2011 Impala
pioneer headunit
2 re audio sxx 15's
hifonics brz24001.d
crunch 1400.4
  • Who's Online   0 Members, 0 Anonymous, 16732 Guests (See full list)
