Good question. IMO i would use a DMM and match off the lowest power. So whichever amp reads the lowest volume at maxed unclipped signal would be where i start.
In for answer
Less gain. Less output voltage. Otherwise you'll clip on one amp
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
When using the CC-1 to gain match my two sub amps, does it matter which one I take the initial reading from? Or should I take the initial reading from the one with more(or less) gain?
less. This way the smaller one doesn't get turned UP to match the bigger one, possibly putting it in the distortion range. I have found though that when using the DD-1, the gain didn't have to be moved very much at all for perfect calibration with the CC-1. But definitely use the smaller one as reference, you shouldn't have to turn the other one down but a hair at the most.
Follow my Tweet (Twitter)
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
