des343 Posted March 10, 2013 Report Posted March 10, 2013 I just installed a set of 6.5 comps on my blazer they are the alpine type s. I amped them to a 4-channel The crossovers are inline crossovers I am fairly sure i wired everything right I wired the crossover to the tweeter then wired it to the + and - to the + and - of the speakers and then used the other 2 terminals + and - so I power everything up the 6.5 mid sub was working and pounding away butnibheard NOTHING from the tweeters so I turned the gain up on the amp and they started making really weird popping/ crackling sounds but no music and those sounds are even very faint What could I have done wrong? In could have wired them wrong but can imagine how ? Please help me first time ive ever dealt with comp sets
ImaNoob Posted March 10, 2013 Report Posted March 10, 2013 Im new to this so, i dont have alot of imput, i would double check all wiring again as per manual. Turn your gains all the way down and make sure Amp and HU crossover is correct..I have been told 100hz... 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
des343 Posted March 10, 2013 Author Report Posted March 10, 2013 Thank u I plan to rip it all back down and double check working I'm almost certain its right but always worth checking. And I missed with all the different gains on the amp it changed the sound from the tweeters but still bad sounds and not musical
fox_racin4 Posted March 10, 2013 Report Posted March 10, 2013 Blown tweets possibly 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
des343 Posted March 11, 2013 Author Report Posted March 11, 2013 They are brand new I'd really hope they weren't blown already
des343 Posted March 11, 2013 Author Report Posted March 11, 2013 Any other ideas I'm really at a loss
ImaNoob Posted March 11, 2013 Report Posted March 11, 2013 Check em with a Dmm, you might have blown them though, with the gain/ wrong frequency on cross over 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
HunterJohnson Posted March 11, 2013 Report Posted March 11, 2013 tweets are blown or you have a crossover set on your amplifier. Your amp should be set to full or NO Crossover and to check ur tweeter hook it up to a dmm and read ohms and test with batter +/- Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
des343 Posted March 12, 2013 Author Report Posted March 12, 2013 Okay I'll do that and check them. But as far as the gains go I tried high pass and full pass which is what I tried first and tried messing with the frequency gains I got different tones but none were musical or good sounding As far as blowing them the amp does 75 RMS a channel the speakers are 80 or 85 RMS so that shouldn't be the case..also the fact of they were hooked up for only minutes while in was playing with the amp trying to get the tweets to work. And I never turned the gains on the amp all the way up so if they are blown they came in the box that way...hope thats not the case :/
Skullz Posted March 12, 2013 Report Posted March 12, 2013 To wire components they will always have an input + and - which you will use to hook your amp to, from there you will have mid output + and - which you connect to the mids and finally the tweeter output which you connect + and - to, if you didn't wire exactly like that then you have it wired wrong and possibly blew something. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
