Ollierides Posted March 12, 2013 Report Posted March 12, 2013 Hi guy's , just bought a secondhand splx 15 dvc 2ohm , going to run at 1ohm off a 1400rms dtr soundstream amp . Please help me design a box !!! Medium size , Good for music but also hitting low for some shake (Y) maybe 32hz or 33 what you reckon ?? Want a basic rectangular port and will face this and the sub upward . Please can someone advise me on box dimensions . Either inches or mm for each piece , send me a link to a good box , and help me figure a good HZ tune . Thanks guys Ollie(16) from New Zealand
Joe X Posted March 12, 2013 Report Posted March 12, 2013 Post vehicle model and max dimensions for a box.
Ollierides Posted March 13, 2013 Author Report Posted March 13, 2013 Hi Joe it is a 1996 Toyota Caldina , sizes would be 3ft wide (36inchs) and 20inchs high and deep . maximum . Aiming for 32 , 33 , 34 tune . What do you think ?? Hope you can help me design my box . Cheers BTW am wanting to aim the sub and port upward toward the roofline
Joe X Posted March 13, 2013 Report Posted March 13, 2013 In that kind of vehicle sub up/port back would likely give better results, either way I would need your max dims for a box and type of music you listen.
Ollierides Posted March 13, 2013 Author Report Posted March 13, 2013 Listen to mostly Hip hop and some heavy bass tracks , want it low but still able to play music crisp . Looking for some good excursion and shake etc when cranked up . The max size the box could be is width of 36inchs , depth of 20inchs and height of 20inchs . Can you work anything out from this ?? Here is the subwoofer specification website ... http://www.soundstream.com/manuals/2009/SPLX-HX%20woofers.pdf Thanks , ollie
Joe X Posted March 13, 2013 Report Posted March 13, 2013 So here is a suggestion: Enclosure Specifications:Fb = 34 HzVb = 3.9 ft^3External Height = 16 inExternal Width = 36 inExternal Depth = 20 inPort Width = 4 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 36 x 20Left & Right Sides =Side 1 = 18 1/2 x 13 3/4Side 2 = 19 1/4 x 13 3/4Front = 31 1/4 x 13 3/4Back = 36 x 13 3/4L Port Internal Assembly Parts:Front to Back = 14 1/2 x 13 3/4Extension = 4 3/4 x 13 3/4 Assembly guide (generic dimensions): Important notes:- The port needs 4" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested.
Ollierides Posted March 14, 2013 Author Report Posted March 14, 2013 Joe you are just awesome , thankyou so much . Add me for a chat sometime
Ollierides Posted March 15, 2013 Author Report Posted March 15, 2013 Hi joe , just one question . Why are the sides different lengths ?? thanks , hope you reply
