Soundstream Splx 15 box help !!!
Ollierides
Hi guy's , just bought a secondhand splx 15 dvc 2ohm , going to run at 1ohm off a 1400rms dtr soundstream amp .
Please help me design a box !!!
Medium size , Good for music but also hitting low for some shake (Y) maybe 32hz or 33 what you reckon ??
Want a basic rectangular port and will face this and the sub upward .
Please can someone advise me on box dimensions . Either inches or mm for each piece , send me a link to a good box , and help me figure a good HZ tune .
Thanks guys Ollie(16) from New Zealand
Hi Joe it is a 1996 Toyota Caldina , sizes would be 3ft wide (36inchs) and 20inchs high and deep . maximum . Aiming for 32 , 33 , 34 tune . What do you think ?? Hope you can help me design my box . Cheers
BTW am wanting to aim the sub and port upward toward the roofline
Listen to mostly Hip hop and some heavy bass tracks , want it low but still able to play music crisp . Looking for some good excursion and shake etc when cranked up . The max size the box could be is width of 36inchs , depth of 20inchs and height of 20inchs . Can you work anything out from this ??
Here is the subwoofer specification website ... http://www.soundstream.com/manuals/2009/SPLX-HX%20woofers.pdf
Thanks , ollie
So here is a suggestion:
Enclosure Specifications:
Fb = 34 Hz
Vb = 3.9 ft^3
External Height = 16 in
External Width = 36 in
External Depth = 20 in
Port Width = 4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 36 x 20
Left & Right Sides =
Side 1 = 18 1/2 x 13 3/4
Side 2 = 19 1/4 x 13 3/4
Front = 31 1/4 x 13 3/4
Back = 36 x 13 3/4
L Port Internal Assembly Parts:
Front to Back = 14 1/2 x 13 3/4
Extension = 4 3/4 x 13 3/4
Assembly guide (generic dimensions):
Important notes:
- The port needs 4" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
  • Who's Online   0 Members, 0 Anonymous, 720 Guests (See full list)
