Parallel vs Series Charging
So can u do any old battery or do they make special 24v batteries?
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
You can wire any (2) 12 volt batteries wired in series to get 24 volts. But they have to be the same battery and in similar condition.
Out of curiosity: what are you doing with 24v?
So then y if u over charge a battery it can swell but charging it in series won't? I'm curious on all this now too
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Who said anything about it not swelling in series? Any time you charge a battery at too-high a voltage it will gas and swell.
So how do u change a 24v series bank? Like say a locomotive runs on 72v are those special batteries or what? How do u change a series bank of 12v batteries?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Just like a 12 volt battery but double the voltage
You are overthinking this way too much lol
Battery101:
- Batteries are composed up of individual "cells" which, as a rule of thumb, need to be charged at 2.3-2.4 volts.
- Battery cells have a nominal voltage of 2v. So 12v/2=6. 6 cells for a 12v battery. And 24/2=12 cells for a 24 volt battery
- A 12 volt battery has 6 of these cells wired in series. 2.3*6 is 13.8v and 2.4*6 is 14.4v.
- A 24 volt battery has 12 of these cells wired in series. So instead of multiplying the cell voltage by 6, you need to multiply it by 12. I'll let you do that so you learn a little
Now whether you have 12 of these cells wired together in 1 battery have 2, 6 cell batteries wired together makes no difference.
It's JUST like a 12 volt battery. But because there are double the cells, all your voltages are doubled too
You can charge series at 24v because the batteries (multiples of 2 for 24v) in series connection puts all the internal cells (a battery is actually many smaller batteries together) in series (2+2+2+2+2+2 + 2+2+2+2+2+2 = 24).
1 battery: 12 volts.
2 batteries series: 24 volts
2 batteries parallel: 12 volts
3 batteries series: 36 volts
3 batteries parallel: 12 volts
4 batteries series: 48 volts
4 batteries parallel: 12 volts
4 batteries series/parallel: 24 volts
etc...
I left out a few configurations but dont worry about them.
edit - sniped.
edit 2
As to the reason for swelling, its because you create heat and chemical reactions within the battery (this can cause them to swell, melt, or explode) when you charge them. Charging at 2.3 or 2.4 volts per cell is pretty safe but getting up over that for longer periods of time or on older batteries will cause failures in many "average" quality batteries. SO if you are charging a single 12v battery then 13.8-14.4 volts is ok. If you run two batteries in a series connection for 24v then your limit is about 27.2-28.8v. If you run two batteries in parallel you are stuck again at 13.8-14.4v.
Hammerdown... 1%
what happens is THIS
when you go series you drop voltage across loads. so lets say you have some 2 ohm 6.5"s rated for 40wrms and you were to wire them in series at 4 ohms and feed them 80w. this would give you 17.89VAC and 4.47 A of current. now when this goes across the speakers in series each is going to see ~8.95VAC and 4.47a. <<<<<<THIS is 40W into 2 ohms
no when you paralell its the opposite lets say those were 8 ohm speakers and you fed them the same 80w at 4 ohms. your amp would put out the same 17.89VAC and 4.47A but instead each speaker would see 17.89VAC and 2.24A <<<<<<<THIS is 40W at 8 ohms.
now lets make these speakers batts and you paralell them your going to gain A but when in series youll gain VDC
hopefully this takes all the dumbshit out of having to wrap your brain around this topic as NONE of these replies explained what your asking.
Ummmm..... WHAT?
  • Who's Online   0 Members, 0 Anonymous, 1117 Guests (See full list)
