So I got into my car this afternoon turned on the radio and I had no sound output from any of speajers or my subs. I checked all my connections, and grounds. Everything seems good. None of the fuses to my battery or amp are blown. The weird parts is when I change the input source on the headunit I can still hear the beep but I get no music from any input source. Any help or advice would be greatly appreciated
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
Have you checked your outputs with a DMM to be sure you are getting a signal?
check the rca cables..... that always get me and i start freaking out when i forget to plug em in or if they came loose
[sharedmedia=garage:vehicles:2273]
May be experiencing a known issue:
Apparently a firmware upgrade was issued for that but I advise not to apply it unless any other alternatives have been tried:
http://www.kenwood.com/cs/ce/receiver/firmware/2012/flip_eng.html
Thank you that is the exact problem I have and a solution.
So the DSP bypass trick explained in the video does work however It does remove most of the equalizer and tuning features incuded in the head units.
Im still not sure what my issue was but I completely reset the unit and all my sound was restored.
  • Who's Online   0 Members, 0 Anonymous, 559 Guests (See full list)
