XS Power
what to use just for starting
So I'm assuming 1900w rms system? First of all, you won't need a battery isolater. You can either check the fitment guide on XS Power or just measure your current underhood battery and get a battery with the same, or smaller dimensions.
Keep in mind, you cannot use an XP model battery for underhood purposes. You will need a D or S model. The D and S is the same thing, with a different label.
06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
I'm planning on doing a true 3800watt max system with a high output alt and a xspower xp950 battery in the back hooked up to a battery isolator. What battery should I go with up front for starting? I have a 98 chevy blazer, I'm limited on space and need to use side post adapters.
Is it a 98 s-10 type blazer?
! have a 99 s10 blazer. I just installed a d3400. It was a bit tight, but, fit fine........I removed the rad cap, and it slid right in....
  • Who's Online   0 Members, 0 Anonymous, 1668 Guests (See full list)
