MD7786 Posted March 27, 2013 Author Report Posted March 27, 2013 So turn the subsonic filter on oround 28 to 30
DubNDodge Posted March 27, 2013 Report Posted March 27, 2013 So turn the subsonic filter on oround 28 to 30 yes..... you were told that already set it at around 28-30hz to keep the sub safe. none of this answers why you had a sudden derease in volume though. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Guest Posted March 27, 2013 Report Posted March 27, 2013 No I have the jl 1000/1. It days amp lp filter. Mode/slope. Off/12db/24db. With fq 0 to 200. That's boost? ohhh okay, yeah i forgot it had that selectable slope stuff. disregard what i said about the boost then.
BoomZoom808 Posted March 28, 2013 Report Posted March 28, 2013 I have a JL 500/1 should have same controls if the bass EQ is turned off it will not bump as hard the JL built in controls are sweet. I would set LPF to ON 24db slope @ 80hz Bass EQ ON Center freq to 40-55 hz Boost to +4-6 Subsonic to 24db slope @ 30hz or so 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
BoomZoom808 Posted March 28, 2013 Report Posted March 28, 2013 Sensitivity should also be set to low if you are using RCA's 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
