What do you think is the problem
What up fam, I am currently running 1 SA-8 in a ported box being powered by a MBquart 1600, I have 1 4 gauge power run and a 4 gauge ground using a body ground. I was bumpin and my amp cut off..I turned car off and my beats came back on..
-So is it that the 4 gauge is not enough to handle the draw
-the stock alt not putting enough out
-Ground is not a good ground
-speaker wire on sub is two thin
4 gauge power wire w/inline fuse(not blown)
4 gauge ground wire(paint is stripped clean and nut with lock washer and crimped terminal)
12 gauge speaker wire from amp to sub and bridging sub down to 1 ohm)
I also will be upgrading to a dual 8 set up sooooonnn
Any advise?
any of those could be the problem. easiest way for us to help you would be to take pictures of every connection and post them here.
get a voltage meter and put it on the input side of the amp. turn up the volume and see what the lowest number is that you get, and tell us.
Could be several things from the gains not set correctly to loose wire some where.how did u set the gain on the amp?
I
Is that amp 1ohm stable?
That can through you into protect mode if its not!
I believe it is 1ohm stable if its the one I have in mind so he should be good
Check the remote wire as well. Both coming from the head unit or wherever you tapped the remote into, and check it at the amp. Make sure that's not a loose connection that got too loose and broke contact after hitting a bump.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
was your amp overheating i know some amps when turned off then back on will play if overheated
  • Who's Online   1 Member, 0 Anonymous, 728 Guests (See full list)
